ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: The Whaler GAM or General Area USCG SPC-LE manual on Ethanol or Methanol Fuel Use
Author | Topic: USCG SPC-LE manual on Ethanol or Methanol Fuel Use |
JTC |
posted 02-05-2013 09:06 PM ET (US)
Found this on line: http://www.uscg.mil/directives/cim/16000-16999/CIM_16114_40.pdf My favorite line so far: "Fuels containing ethanol or methanol should be avoided whenever possible. These additives may cause corrosion of metal parts, deterioration of rubber and plastic parts, fuel permeation through rubber hose lines, and difficulty in starting and operating the engines. The fuel hoses, filters, and connections should be inspected frequently when using fuel with alcohol additives." |
posted 02-05-2013 10:18 PM ET (US)
Methanol is not commonly used as an additive to gasoline any more.
quote: Source: http://www.afdc.energy.gov/pdfs/mit_methanol_white_paper.pdf |
