   1988 13' Super Sport , 35 Mercury in Atlanta
Author Topic:   1988 13' Super Sport , 35 Mercury in Atlanta
bikingart posted 04-23-2008 02:54 PM ET (US)   Profile for bikingart   Send Email to bikingart
HULL
Light, dry , unmolested, garage kept fresh water hull that I have reconditioned to the highest standards sparing no expense or time. Number is BWCM2527D888 rigged as it left the dealer. All wood removed and stripped or replaced with new matching mahogany and expertly refinished with 10 coats of Interlux Schooner spar varnish and looks and smells better than new. No wood stain or epoxy used. Gel coat in and out is glossy . No damage history. New rub rail and decals. Rails and hardware are like new. Some non skid under the fuel tank mat has been worn smooth which is cosmetic only. Never bottom painted and no spider cracks. Nav lights and recent acrylic trailing cover.
ENGINE
1988 Mercury 35. Model # ELPT 35, serial # OB271598., power tilt and trim, comperssion 145 psi on both cylinders, fresh fuel filter, plugs, water pump impeller. lower unit service, carbs serviced, new 13 pitch alumimum prop with vortex hub. No corrosion with shiny original paint with a few small scratches, This is one of the lighest engines with tilt and trim allowing the boat to float high in the water.. I see 31 mph on a GPS at 5500 RPM which is pretty much what the 40 HP boats do with somewhat less acceleration out of the hole. .Motor has seen some salt water use, although I have used it only in fresh water. . Oil injection is disconnected and runs on 50:1 premix.. Starts quickly and runs perfectly.
TRAILER
1987 Noeshel model ET 16, galvanized , serial number N870352 New parts include soft springs, hubs, bearings, 12” wheels and tires. Never in salt water and ready to go anywhere. Includes spare and tongue wheelstand.
This classic rig is turn key ready and is offered because I rarely use it at $6400.00 pretty firm, at least for now. It was for sale last Fall, but was withdrawn from the market. I also own a super Sport 15 and a classic Montauk. The price is clearly toward the upper range for this model and reflects it’s condition and uniqness. Ultimately the market will set the selling price. It is not advertised anywhere else as of this date, but I plan to try EBay / Boat Trader for a wider audiance if nothing happens here.
Request 14 photos from artmolitor@yahoo.com
Call Art with questions or for an appointment. Located in my garage in NE Atlanta. 404-226-8345. artmolitor@yahoo.com. Only interested and qualified buyers please.
bikingart posted 05-01-2008 09:30 PM ET (US)     Profile for bikingart  Send Email to bikingart
This boat is now on E Bay with photos. Item # 300221211414.
Thanks,
Art
