  hull number
Author Topic:   hull number
whfrazier posted 07-02-2008 11:17 PM ET (US)   Profile for whfrazier   Send Email to whfrazier
just picked up an old (late 60's/early 70's) 13 ft fixer upper (you'll be hearing more about this project!). Interior has been repainted so I can't find a hull number. A previous post had the same problem... I sanded off the 2nd coat of paint on the interior side of the stern just below the motor cut-out but cannot find the BW number. Any other ideas where to look??? Any suggestions appreciated... hank
bkovak posted 07-03-2008 07:02 AM ET (US)     Profile for bkovak  Send Email to bkovak
Hank, look in the bottom of the front anchor locker or on the inside rear wall of it. My old blue nauset from the 60's had a hull number located in there. Brian
whfrazier posted 07-03-2008 07:56 AM ET (US)     Profile for whfrazier  Send Email to whfrazier
thanks Brian... will get the sandpaper out this AM and get to it. hank
whfrazier posted 07-04-2008 04:43 PM ET (US)     Profile for whfrazier  Send Email to whfrazier
Brian... found it; in the bottom of forward locker. #5286... can't see anymore as there is significant ding underneath left side of number. thanks for the advice... hank
bkovak posted 07-04-2008 10:13 PM ET (US)     Profile for bkovak  Send Email to bkovak
Hank,
Great! I believe there may be one more number in the sequence. Mine has 5 numbers and have have seen several others with 5 as well. Maybe Tom Clark or someone here with more knowledge of the old numbering system would know. Could be hidden under the "ding" you mentioned. Brian
whfrazier posted 07-05-2008 06:33 PM ET (US)     Profile for whfrazier  Send Email to whfrazier
Brian... I can barely make out the 5; 286 are pretty clear. If this is the entire number, then the boat must be '61-'63 model. If it is missing a 2A (for example), then it would be a '70 or so. Any way to determine early 60's boat from an early '70's??? For sure, this is the old style; full bulkhead in the stern; cutout transom; full length bow locker; etc. Suggestions welcome... thanks Hank
deepwater posted 07-06-2008 07:58 AM ET (US)     Profile for deepwater  Send Email to deepwater
if you move this to the gam area you will get more info
whfrazier posted 07-06-2008 09:40 AM ET (US)     Profile for whfrazier  Send Email to whfrazier
Thanks Deepwater... how do I do that?? I was afraid I had posted in wrong area but didn't know how to move it without staring dupe thread. Help needed.... hank
