  FS 50 HP Evinrude, 4-Stroke, EFI
Author Topic:   FS 50 HP Evinrude, 4-Stroke, EFI
cindalyn posted 10-08-2008 02:41 PM ET (US)   Profile for cindalyn   Send Email to cindalyn
For Sale ā€“ 1999 Evinrude 50 HP, Four Stroke, Electric Fuel Injection (EFI), Power Tilt & Trim, Spare prop, controls, Evinrude gauge, plus service and maintenance manuals. $2,000 [Conway, SC]
I am currently using this engine which has approximately 120 hours. Recently computer checked ā€“ all systems OK and compression is OK. Recent maintenance included new plugs, impeller, thermostat, oil and filters, Engines runs to full 6,500 RPM per specification
This engine is VERY fuel efficient ā€“ it sips gas and is very quiet
Under the cover/hood the engine appearance is almost like new. The cover/hood has a slight scuff which can be touched up with paint.
It will be the responsibility of the buyer to remove the engine [238 lb.] from the boat and for any shipping expenses.
The engine will be sold as-is, where-is prior to removing from the boat.
To my knowledge this engine has never been in saltwater and I was told by the previous owner that the engine hour meter is correct.
Iā€™m selling this engine because my boat is too heavy for 50 HP and I would like to buy something larger. I really bought the engine only because it came with the boat I wanted.
See specifications and pictures below:
o Evinrude - Model E50PL4EES 1999
o Horse Power: 50
o Shaft: 20
o Displacement: 49.7 cu. in. (815 cc)
o Weight: 243
o Cylinders: I-3
o Bore X Stroke: 2.80 x 2.70 in. (71 x 68.6 mm)
o Ignition: Solid State Direct Ignition
o RPM Range: 5900-6500
o Maximum RPM: 6500
o Starter: E Start w/ Electric Fuel Injection (EFI)
o Oil Tank Capacity: 2.2 qt. (2.1 lit.)
o Alternator: 12V 18A
o Trim Position: Power Trim
o Fuel: Unleaded
o Gear Ratio: 2.27:1
o Drive Train Protection: Spline Drive Rubber Hub
o Standard Propeller: Optional
o Available Prop Pitches: 9-17
o Steering: Remote (Tiller Kit optional)
o Features
o Water-Cooled Vapor Separator/Fuel Pump
o Sequential Multi-Point Fuel Injection
o Clean and Efficient
o On-Board Computer Diagnostics
o Unique Low Gear Ratio
o Cool Air Intake System
o Dual Water Intakes
o Solid State Full Transistor Ignition
o Direct Ignition
o 3-Stage Baffle Chamber and Thru-Hub Exhaust
o Multi-Function Center Tiller Handle Option
o EZ Oil Drain Plug
o Idle Air Control
o One-Piece Forged Crankshaft
o 3-Star Ultra-Low Emission CARB Rating
o Oil-Bathed Timing Chain
o Tuned Intake System
o 16-Valve DOHC (Dual Overhead Cam) Design
o Stainless Steel Water Pump Housing
http://www.boatpoint.com.au/Story/OMC-Evinrudes-new-Suzuki-designed-four-strokes/1947991.aspx
dklett posted 10-10-2008 01:11 PM ET (US)     Profile for dklett  Send Email to dklett
Please call 732-690-3054 if still for sale.
cjgmtp posted 10-12-2008 03:48 PM ET (US)     Profile for cjgmtp  Send Email to cjgmtp
i am interested in the engine. i am loking to repower a 15-sport. i am in mt. pleasant please call me @ 843-991-7056
