  EdgeWater 175CC, 125hp Mercury, Trailer
Author Topic:   EdgeWater 175CC, 125hp Mercury, Trailer
daleruss posted 02-15-2009 02:23 PM ET (US)   Profile for daleruss   Send Email to daleruss
The EdgeWater 175 center console was manufactured by Dougherty Marine in Edgewater, Florida. Bob Dougherty, the former chief engineer and designer of Boston Whaler for many years, started EdgeWater Marine in the 1990's when Boston Whaler was sold. He designed and built the 175 center console which has the same style and lines as the classic 18' Outrage built by Boston Whaler during the 1980's - early 1990's. The EdgeWater is a foam filled hull and is unsinkable with all the great features carried over from Boston whaler but with modern features and advanced materials.
Unlike Boston Whaler, EdgeWater uses a 100% composite core with no wood which could rot, EdgeWater offers a full lifetime (transferable) hull warranty (instead of just 10 years). The 175 center console has an 18' centerline length and a wide 7.4 foot beam and is very roomy and stable for its size.
This one owner 2001 EdgeWater is self bailing. The hull, floor and transom are solid. This hull is in excellent condition. There are 2 recessed rod holders in the gunnels and 4 rod holders built into the center console, which drain, along with a livewell under the seat. The large swingback helm seat has an Igloo cooler underneath and 2 additional rod holders with a removable padded back rest. The console is hinged and tilts forward for easy access to wiring, steering system, controls and the 2 batteries and offers a small storage area. There are no electronics. There is a built in 45 gallon fuel tank. The boat has a speedometer, tachometer, fuel gauge, voltmeter, and hour meter with 173 hours on it. The steering is mechanical and has a superb response while running. A washdown pump and hose attachment is also mounted in the console. A factory stainless steel Bimini top as well as a Sunbrella full mooring cover is included. This EdgeWater was built with all available options including a full cushion set and interior lighting.
The motor is a 2003 Mercury 125 hp, 2 stroke with a stainless steel prop. It has 177 hours use. The motor starts easy, runs strong and is very quiet and fuel efficient. It was used in freshwater lakes and in the Gulf of Mexico. I have flushed the boat, motor, and trailer after each saltwater use. The motor is very clean and runs great. It was recently serviced by a certified Mercury mechanic and has new water pump, spark plugs, and fuel filter. It has a top speed of just over 40 mph in calm conditions. A water separating fuel filter is mounted in the stern. The hull is a modified V hull design with reverse chines and cuts through waves easily, offering a dry ride. The high freeboard makes you feel safe and comfortable even in rough conditions. The boat can go in as little as 10" of water with the motor trimmed up. There is power tilt and trim on both the motor and at the helm.
This boat is rated for 7 passengers and has a capacity of 1700 lbs. It is set up to seat 7 with the front livewell seat attached to the console, the leaning post and two rear jump seats with back rest cushions. The seats are in very nice condition. The boat has a 45 gal built-in tank. There is a very large bow deck which is a great casting platform with a removable bow cushion and a deep well is located under the bow hatch. A swim platform with folding step is mounted on the stern. An automatic bilge pump is mounted in the rear bilge along with the baitwell pump. EdgeWater uses high quality stainless rails, hardware and fasteners and is a high quality boat that handles great in all types of conditions. The hull is easy to wash down and maintain and the gelcoat shines like glass. An anchor, fire extinguisher, life vests, throw cushion and whistle are included.
The boat is on an all aluminum 2001 Loadmaster bunk trailer with 14" wheels, and LED lights. The boat only weighs 1300 lbs without the motor. The trailer is oversized and has a capacity of 3500 lbs which supports the boat well. It has guide posts, launches and tows easily and is in great shape for highway travel. This is a great late model, unsinkable 18' center console boat with lots of room and stability and newer dependable Mercury power and trailer. Overall, the boat, motor and trailer are in excellent condition. This boat is turn key and water ready to take out fishing tomorrow. It is a blast to operate and very dependable. Why settle for an older Boston Whaler Montauk or Outrage for a similar price when you can have a newer Dougherty built EdgeWater with a lifetime hull warranty?
This EdgeWater is located in Tampa, Florida. All of the original boat, motor, and trailer owners manuals and documents will be provided to the new owner.
Contact daler7@msn.com or 813 748-9447
Tohsgib posted 02-15-2009 06:39 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Now that is how you should post an ad. Jim does not charge you by the letter so go for it and let it all hang out.
Price and lack of Whaler bashing would however be appreciated.
daleruss posted 02-16-2009 09:19 AM ET (US)     Profile for daleruss  Send Email to daleruss
Sorry if ad reads like it is Whaler bashing. Did not mean for it to sound that way. I was simply pointing out the differences to the two boat lines. I have owned and currently own Whalers, so I definitely was not trying to put Whalers down.
As far as price, I do apologize that it was left out, $14,500. Thanks
stayinstrewn posted 02-16-2009 10:37 AM ET (US)     Profile for stayinstrewn  Send Email to stayinstrewn
pictures?? sounds like a great boat
Newtauk1 posted 02-16-2009 10:44 AM ET (US)     Profile for Newtauk1  Send Email to Newtauk1
Has the boat been bottom painted?
Jeff posted 02-16-2009 11:17 AM ET (US)     Profile for Jeff  Send Email to Jeff
I found an 17' 6" Edgewater just over a year ago when I was looking for a Whaler to replace my Outrage. I still wish to this day I had bought that boat but I just had to have a whaler. The one I found was listed at a price that was comparable to a good condition 80's Montauk and sat on the Market for months (poor advertising and an owner who did not know what he had). Great looking solid boat and would be a great boat for someone looking at a Montauk, 17 Outrage I, or an classic 18 Outrage. Good luck Dale.
Here is the boat I looked at, is this the same general layout as yours Dale?
http://s32.photobucket.com/albums/d1/whalerforsale/ 176%201998%20edgewater/
daleruss posted 02-16-2009 05:10 PM ET (US)     Profile for daleruss  Send Email to daleruss
Thanks guys for the nice comments. Here is my best attempt to post photos. If anyone could active this link I would appreciate it.
http://s153.photobucket.com/albums/s218/daleruss/Edgewater%20175CC/
Newtauk1, Boat has not been bottom painted, never been left in the water.
Jeff, it looks very similar to the one you posted, I think mine may be a littler newer and that would expain some of the subtle differences.
And thanks to all for wishing me luck!
Newtauk1 posted 02-16-2009 05:44 PM ET (US)     Profile for Newtauk1  Send Email to Newtauk1
jimh posted 02-20-2009 09:36 AM ET (US)     Profile for jimh  Send Email to jimh
To discuss the history of the Everglades Boat company, please use THE GAM as your forum. MARKETPLACE is intended only for notices of for-sale or wanted-to-buy. Thank you.
