ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Marketplace FS: Perko Flush Mount Vertical SS rod holders
Author | Topic: FS: Perko Flush Mount Vertical SS rod holders |
L H G |
posted 02-25-2012 02:10 PM ET (US)
These are brand new, never installed or used, for either gunwale or RPS seat back installation. The top diameter is 3-1/2" so be sure your RPS seat top has not been excessively sanded down to less than that width dimension. They are 90 degree vertical, and a very high quality fitting, complete with rubber cap fitting, if needed. This cap would be used for a gunwale installation, but not in the RPS. I don't have photos, but you can see it here: http://www.perko.com/catalog/category/fishing_equipment/product/309/ Shipping included, a bargain to your door price of $95 for BOTH. |
aubv |
posted 02-25-2012 04:29 PM ET (US)
L H G, If they have a Gimbal pin or bar I am interested. |
L H G |
posted 02-25-2012 05:01 PM ET (US)
The entire black plastic interior lining of the rod holder terminates in the closed bottom perforated with small holes so that water would drain out. Also mounded into this liner is a raised "bar" across the bottom, about 1/4" high I would guess, that is clearly intended to work as a gimbal pin so that a rod with a split butt would not rotate when sitting in it. But it is not a separate metal pin. I should also say that this is Perko part # 0447DP1CHR. |
Marko888 |
posted 02-27-2012 11:04 PM ET (US)
L H G, I'm also interested. email me on mcahill at allterrasurvey.ca Thanks Mark |
MarkoOR18 |
posted 02-28-2012 12:51 AM ET (US)
I'm out. My RPS top is only 3 1/4" wide. Bummer |
MarkoOR18 |
posted 03-01-2012 12:10 AM ET (US)
L H G, How is the flange constructed? Could the outer diameter be turned down on a lathe to make it's total diameter slightly less than 3 1/4" ? If so, I'm in! thanks Mark |
L H G |
posted 03-01-2012 02:19 AM ET (US)
Mark - The top circular flange is 1/16" SS. The edges of the three countersunk mounting holes are 1/16" from the outside, so I don't think you would want to turn down the entire outside diameter 1/16". Instead you might be better to "flat side" each edge, or actually, I don't think the 1/16" overhang on each side of the RPS would look that bad, or even be noticeable. If you want I will send you one at no cost to see if you like the fit without alteration, and if you don't want it you can send it back. Or if you do, I will send the other and we can conclude the deal. |
aubv |
posted 03-01-2012 07:49 AM ET (US)
L H G, If all else fails, you can still send me an e-mail. |
MarkoOR18 |
posted 03-01-2012 10:34 AM ET (US)
That would work Larry. I realize I'm the second poster here but I would take them if the Aubv passes. Just send me an email so I can arrange payment. My email is noted above. Thanks Mark |
L H G |
posted 03-02-2012 02:34 PM ET (US)
Confirming the rod holders SOLD to AUBV. Mark - thank you also for your interest. |
MarkoOR18 |
posted 03-02-2012 04:51 PM ET (US)
Cool. Thanks for letting me know. |
