posted 04-10-2000 07:39 PM ET (US)
DMW - Couple of questions:
What condition is the insides i.e. did the previous owner also sand down the inside and attempt the glass it or is the cobble job just on the outer hull?.
Whats your experience level with glass repair and painting?.
Where are you located, west, midwest or east coast?.
Got air powered or access to airpowered tools, mainly sanders?
Hows the wood?
Any evidence of dry rot in the transom?
Re-gelcoat is possible, a lot of sanding is required. Most importantly, is a smooth, really smooth surface. Then and only then do you made the decision to either regel or paint, with a 2 part polyurthane or have it done. With the paint, once it's on, with multiple coats, you don't have to sand it. With the gel, you will have to sand. The gel is thicker then paint. If you were to keep it in the water all season, I'd lean toward the gel, if keeping it on a trailer, I'd lean toward the paint. You also need to think about _how_ you plan on using it, once redone... i.e. gonna run it up on to a sandy beach or keep it off the beaches. A sand beach will play hell with paint quicker then gel. Paint will give a shiner (my opinion) coat with less, no, make that MUCH less work.
