posted 06-05-2000 12:43 AM ET (US)
Someone had a good URL to the sequence of assembly/disassembly...but I can't find it right now.Short version:
Persuade Bearing Buddy to come off by tapping with hammer, back and forth, rocking it out of the end of the hub. This will reveal greasy inner workings.
Now jack up trailer so wheel is off the ground slightly.
Dive into greasy inner workings to find hub retaining nut threaded on end of axle and secured with either a cotterpin or some type of tabed washer.
Remove cotterpin or bend tabs.
Back nut off the axle. For some reason I think there might be a left hand thread in here somewhere--I don't recall exactly.
Hub can now be removed from axle.
Hub should come off easily, with parts in this order, working from outermost to innermost:
Grease seal / Outer Bearing / Bearing Race / HUB / Bearing Race / Inner Bearing / Grease Seal.
You can pry out the grease seals (destroying them in the process) with a large screwdriver.
The bearings should come out easily.
The bearing races will not come out without a lot of effort, hammering, etc.
Putting new bearing races in is a little touchy, too. They should be installed with a special seating tool, which you won't have.
THE BOOK always says never to use old races with new bearings, but I ended up doing just that and its been working for 8,000 miles.
But if your bearings are OK, you can just replace the grease, and install new grease seals, and reassemble the whole thing.
There is a technique to how tight the retaining nut is made, including "pre-loading" the bearings. Find some more literature about this, as you will want to get the bearing retaining nut set just right, and I don't remember well enough off the top of my head how to tell you to do it correctly.
Once caution: If you use your finger to reach in to scoop out the grease from the interior of the hub, watch out for sharp machined edges, knife-like edges really, that may lurk in there. I got a very nasty cut in the process of learning that the inner edge of the bearing race seats don't have the corner broken on the machined edge, producing a very sharp surface.
If you put too much pressure into the grease cavity with the bearing buddy gizmo, you can force grease past the inner seal. So just fill the bearing buddy up until the spring starts to compress.
The newer bearing buddies have relief holes that allow the grease to escape if the volume of grease gets so large that the spring loaded seal is compressed too far.
It is better to learn about this in the driveway than along the dusty shoulder of a busy interstate 500 miles from home.
--jimh
