  RUNNING LIGHTS WIRING
Author Topic:   RUNNING LIGHTS WIRING
CARLB posted 07-07-2000 12:25 PM ET (US)   Profile for CARLB   Send Email to CARLB
NEED TO REPLACE THE WIRE FROM STERN TO BOW LIGHTS ON 1969, 16'7" EASTPORT. ANY SUGGESTIONS AS TO HOW OR WHERE WIRE IS RUN IN THE HULL?
lhg posted 07-07-2000 12:38 PM ET (US)     Profile for lhg
Hunt around this forum, as there is previous info on this subject.
CARLB posted 07-08-2000 04:31 PM ET (US)     Profile for CARLB  Send Email to CARLB
lhg:
Saw previous info. Wondered if anyone had any details as to how wire was routed and how to run new wire to bow light.
lhg:
sr posted 07-08-2000 07:45 PM ET (US)     Profile for sr  Send Email to sr
I thought it ran behind the rubrail. Not sure though.
sr
Zack posted 07-10-2000 12:47 PM ET (US)     Profile for Zack  Send Email to Zack
The original wire is molded in the hull. BW put three wires in so you would have a spare. If you do not have any two working you will have to rewire with the new wire hiding under the insert in the rub rail. You will have to drill a small hole in the bow to get the wire to the light, also a small hole on the port aft side to get the wire inside the rubrail insert. Hardest part is putting the insert back in the grooves. Hope this helps, Zack
lhg posted 07-10-2000 01:30 PM ET (US)     Profile for lhg
If you do not have an upgraded 2 piece rubrail on the boat, the only other alternative (as recommended by Whaler) is to run the wire under the gunnel lip, using tape or something to keep it in place. It won't show, but it sure is a good reason to do the rail upgrade. That's what I did on my Nauset, shown in the reference section.
CARLB posted 07-11-2000 11:07 AM ET (US)     Profile for CARLB  Send Email to CARLB
THANKS FOR THE INFORMATION
