posted 09-10-2000 09:19 PM ET (US)
Bellj - I looked at some old Whaler lit, and couldn't find a hardtop model. It may look ok or it may look like _hit, it depends on how much money you want to spend on it and how much experience you've got in doing a large mod.
_If_it_was_my_decision, I'd check some sources for a prefab hardtop and then have a good fabrication shop make the attaching vertical hardware (ss or alum...probably alum)
It will change your cg and trailering weight.
I don't think you'd want to go to the extreme of having some sort of solid glass with frames build, as this is where some serious bucks could get eaten up.
Best (and good luck) - Don
