  water output when running
Author Topic:   water output when running
thunderbay posted 09-11-2000 12:21 AM ET (US)   Profile for thunderbay   Send Email to thunderbay
Got the pinion gear back in, motor is assembled, put a new water pump impeller in, slot is lined up with the pin so I know its ingaged. Belive the tube in the lower unit is connected to the pump, cant really see as it goes together, but sure feels like it. When running in a full garbage can of water, should I have a large stream of water coming out the hole? Thanks
reeltime2 posted 09-11-2000 08:48 AM ET (US)     Profile for reeltime2  Send Email to reeltime2
Yes you should have a strong stream of water. Make sure the tube in the lower unit is installed right you should be able to see it as it goes together it wont just line up automaticly you have to make sure by looking at it as it goes together.
Rick
