posted 01-07-2001 10:51 PM ET (US)
My '97 Montauk came this way. The tank
is 2 gal, mounted in the port forward
corner of the console, with the long axis
of the tank awthartships.Mine sits on the console floor, but I've
considered cutting a hole in the floor so
the tank sits on the deck (in some sort of
tray so spillage stays put) so as to get a
little more console space.
BEFORE you mount
things, see what it will be like to add oil
to the tank. It's a messy job. Try both
gallon and quart containers.
You'll need to put a primer bulb in the line
at the console. Fiddle with the hose lengths
so that bulb tucks out of the way when not
in use.
Run the hose through the floor close to the
tank. Mine came with the hose going way over
into the middle of the biggest piece of
empty floor (DUMB). I relocated it.
Before you first fire it up, you gotta get
ALL the air out of the line. I'd put the
bow all the way down, and pump a couple of
quarts through the line (you can always pour
them back in). Then there's a process for
priming the system in the motor.
Sound like too much work? Another advantage
of a four stroke. ;-)
