posted 02-20-2001 10:21 AM ET (US)
Borrow a different tank, same brand of
motor, and move the quick release over
to the borrowed tank. See if you get gas.Could be:
- No gas in tank (dumb question, but needed
to be asked).
- Clogged pickup on tank (check by removing
the gas cap).
- Plugged vent on tank
- Bad quick disconnect. Could be either an
air leak or the QD not opening.
- Bad primer bulb
- Bad fuel filter(s)
- Bad fuel pump
Put the boat in a WELL ventilated area away
from any open flames or smokers.
Pull the fuel filter at the motor. Wrap a
rag around it. Pump the bulb. Do you get
gas? If yes, it's not the filter, not the
fuel pump. Make sure what you get is GAS,
not water.
Chuck.
