  Rivet removal
Author Topic:   Rivet removal
Scalzo posted 03-10-2001 10:06 PM ET (US)   Profile for Scalzo   Send Email to Scalzo
Anybody know the trick to removing the rivets on the rubrail without taking chunks of fiberglass out of the boat? I'd appreciate any advice. Thanks.
Tom W Clark posted 03-10-2001 11:06 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Use a drill to drill the heads off the rivets. The rub rail is typically held on with 3/16" pop rivets, so use a 3/16" drill bit and the rivet head will come off after you've drilled through the head and into the shank. Once the head is gone, you simply push the remainder of the rivet into the hole. If you are installing new rub rail after this be sure to drill your new holes away from the old ones so you get a good grip.
tarbaby posted 03-11-2001 06:03 PM ET (US)     Profile for tarbaby  Send Email to tarbaby
I agree. Don't forget to fill the old rivet holes with 5200. My two cents
Chesapeake posted 03-11-2001 06:25 PM ET (US)     Profile for Chesapeake  Send Email to Chesapeake
A thickened West epoxy injected into the holes with a syringe works great. Besides being water-proof, it doesn't matter much where you drill your holes for the replacement rail.
Bob
stagalv posted 03-11-2001 10:41 PM ET (US)     Profile for stagalv  Send Email to stagalv
Bob, that is just what I did too. I bought a syringe and some epoxy and injected it. I certainly dont want any old holes to let water in to the core.
It was a chore getting the rivets out. I found the drill to be the best way as well.
Rex
JimU posted 03-12-2001 03:46 PM ET (US)     Profile for JimU  Send Email to JimU
Just got through my second rubrail replacement. Follow above advice. Drill out the rivits with a 1/8 to 3/16 drill. You will know that you have the right size when the flange on the rivit remains on the drill bit after you have drilled through. You won't actually be able to get all the rivit out of the fiberglass. The 'barrel' of the rivit will stay put or will puch through into the foam. Fill the holes with 5200 or west system epoxy and repair any other damage along the gunnel. I used stainless steel pan head sheel metal screws rather than rivits to install the new two piece Barbour rub rail.
