  Transducer placement
Author Topic:   Transducer placement
stagalv posted 04-11-2001 12:03 PM ET (US)   Profile for stagalv   Send Email to stagalv
I am thinking back to a thread from last year. Didn't you guys say it is best to mount any transducers on the port side? I believe this was due to help engine torque, etc..
I am mounting the ducer for a Garmin FF. Thanks for any advice. Rex
Forgot to mention -- boat is an 86 Montauk. Rex
triblet posted 04-11-2001 12:40 PM ET (US)     Profile for triblet  Send Email to triblet
Yep, port side. The prop flow tends to
keep the ducer in the water a little more
on that side.
Cruiser posted 04-21-2001 05:56 PM ET (US)     Profile for Cruiser
I am also replacing a transom transducer. Do I place it inline with the hull angle/V or place it flat such as the water surface will be? How far below the hull bottom should it be mounted. Thank you.
NWflyfisher posted 04-21-2001 08:39 PM ET (US)     Profile for NWflyfisher
I'm replacing an existing transducer from a Furuno FE-606 echo sounder that I'm removing from my Montauk to the Depth/Temp/Speed transducer for my existing Furuno GP-1080F. Instructions say to mount the transducer 8" starboard of the centerline. Not sure what the difference between 8" port of the centerline and 8" starboard of the centerline is, but I'll follow their directions none-the-less.
