posted 05-24-2001 10:37 PM ET (US)
For the buffing, I am currently using Meguire's #44. I like the result. You might also want to try Dolphinite. Remember to follow the buffing with a finer cut product, and then apply a couple of coats of good quality wax.As far as the varnishing, go ahead and use the stripping product you feel comfortable with. If the varnish is thick, you may need to do it twice.
Then begin sanding. Start with 60 grit, then move out to at least 220.
Begin the varnishing by thining the varnish with 25% thinner (this allows better absorbtion of the varnish for the first few coats). Sand the first coat with 400. Then apply another coat and sand again. Now use the full strength varnish. Sand between coats with 400 (lightly). Generally you should be putting on 6-12 coats of varnish. With your final 2-3 coats, use bronze wool instead of the 400 sandpaper (bronze wool is important because the tiny fibres of steel wool that you don't remove will rust).
Follow this procedure, and you should have brightwork that will look very sharp.
