  Mercury 80 HP. 16.4 volts?
Author Topic:   Mercury 80 HP. 16.4 volts?
Arch Autenreith posted 06-05-2001 02:36 PM ET (US)   Profile for Arch Autenreith   Send Email to Arch Autenreith
My Garmin fishfinder keeps shutting off because it is programmed to shut off when battery/charging exceeds 16 volts. I did put in a voltage regulator but now think the constant 16.4 will cook the battery. Anyone know if this is the specified charging volts for a Mercury? 1980 model. BTW, the Garmin tech asked me if it was a Mercury OB because this seems to be a common thing with these engines.
Arch Autenreith posted 06-05-2001 02:45 PM ET (US)     Profile for Arch Autenreith  Send Email to Arch Autenreith
What I meant was does anyone know if thier OB charges at 16+ volts?
lhg posted 06-05-2001 03:00 PM ET (US)     Profile for lhg
Arch - see thread in this section last dated 5/24/01. I had same problem.
Your engine probably needs voltage regulator service. Merc's voltage regulators are capped at 14.2 volts.
Yes, you will damage the battery, if not already. I just went through the same thing.
Arch Autenreith posted 06-05-2001 03:03 PM ET (US)     Profile for Arch Autenreith  Send Email to Arch Autenreith
Thanks, Larry. (It is Larry, isn't it?)
