posted 06-11-2001 12:03 AM ET (US)
With the rotten weather we've been having this spring, refinishing some teak components was about the only thing I could do as far as "working on the boat" was concerned for the past several weeks.I tried the AMAZON products teak finish. I'd seen the results on other Whalers from using this method, and I liked the look.
Their products come with some of the worst instructions I've ever seen. The instructions are not clearly written, simple English. I followed them as best I could. Here is what I did:
First step, wet the wood and surrounding area.
Next, apply the "One Step" CLEANER product and scrub. Use a stiff brush if needed. Rinse with water.
Repeat if necessary. Let dry overnight.
[I did notice that this tended to soften the wood. On follow up pieces I tried to limit the amount of water used to a minimum.]
[AMAZON does not mention this next step but I was advised by an old hand to add it.]
Second, sand surface with "fine" sandpaper and an orbital sander. The wood is soft and comes off rapidly. I was thinking about collecting the sawdust for use in thickening epoxy for some repairs I had to make, too.
I removed the hardware, too.
After sanding, vacuum dust off surface or wipe with tack rag.
[Now back to AMAZON's directions.]
Third, apply coat of TEAK PREP product. This is supposed to drive out any remaining moisture in the wood (the cause of dark streaks) and to neutralize any residue from the CLEANER. Let this dry overnight.
Fourth, mix TEAK PREP and TEAK OIL 1:3 and apply coat. Let dry 5-6 hours.
Repeat another application of TEAK PREP/TEAK OIL mixture. Let dry 5-6 hours.
Finally, apply coat of TEAK OIL full strength. Let dry 5-6 hours. Repeat if desired.
The results are quite nice, but I think the biggest improvement in the wood came from the sanding. Sanding really gave the wood a nice renewed surface. There was still some dark threads in the grain, but I think this might be a bit natural.
The application of the first coat of TEAK PREP really gave the wood a wonderful appearance. I was very impressed with how fine this cabinet door looked! It was furniture grade now!
Of course, as the oil is absorbed the wood loses the gloss. Each coat gets the wood a bit darker, too. I was using the GOLDEN TEAK OIL product; there are two other grades.
I have about 4-5 coats of oil on the cabinet. It looks great.
I'll let you know how the finish holds up at the end of the summer.
--jimh
