  Engine Mount and Wedges on a Sport
Author Topic:   Engine Mount and Wedges on a Sport
John Fitzgerald posted 06-11-2001 12:25 PM ET (US)   Profile for John Fitzgerald   Send Email to John Fitzgerald
I had to remove the engine from my 70 Sport to repair some dings in the hull. Found beneath the Johnson 40 (1988) what looks like plywood siliconed to the transom on the outboard side.
Is this a homemade wedge? Are wedges generally needed on 13's? What is the optimum way to remount the engine?
Thanks in advance.
Fitz
jimh posted 06-12-2001 08:03 PM ET (US)     Profile for jimh  Send Email to jimh
From your description is sounds like a home-made (or dealer added) addition.
Which way does the wedge run? I'd gues it might be thicker at the top, to allow the engine to trim in a bit more.
--jimh
lhg posted 06-12-2001 08:11 PM ET (US)     Profile for lhg
Same old problem with Whalers and OMC engines. OMC's power trim system had inadequate range during those years.
John Fitzgerald posted 06-13-2001 10:33 AM ET (US)     Profile for John Fitzgerald  Send Email to John Fitzgerald
The plywood outline looks like the commercially available (West Marine) aluminum wedges and they run top to bottom. Thickness is a lttle hard to reconstruct because the lower third (guess) was so heavily rotted and fragile. It seems that the wood is 3/16 or 1/4 at the top and the thickness of one plywood layer at the bottom. I would have thought since the transom slants forward as you go down the transom that the thicker part of the wedge should habve been at the bottom so that the engine bracket was more nearly vertical.
lhg posted 06-13-2001 04:12 PM ET (US)     Profile for lhg
No - just the opposite. The thick part of the wedge is at the top. The reason for this is that the OMC engines did not have enough "tuck in" range in the trim system. Usually wedges are used to allow the engine to plane faster and to keep the boat from porpoising while under way. The plywood was some homemade solution! You may have to get a set of the aluminum wedges if the porpoising problem exists.
Whaletosh posted 06-13-2001 08:36 PM ET (US)     Profile for Whaletosh
Larry,
An interesting sidebar, some of the new Impacts that I looked at at shows have had wedges on them
dghinseaford posted 08-28-2009 01:41 PM ET (US)     Profile for dghinseaford  Send Email to dghinseaford
wow, 8 years later as i change motors on my bw impact and try to figure this wedge thing out, i find this post! thanks! dgh
Russ 13 posted 08-29-2009 01:00 AM ET (US)     Profile for Russ 13  Send Email to Russ 13
I used a pair of aluminum wedges from the local Yamaha dealer. I believe they are a sea to sea part.
Ran about $30.00 for the pair, they work well & fit good.
