  Idea's for a rear stern light /PA horn combo assembly
Author Topic:   Idea's for a rear stern light /PA horn combo assembly
Eagleman posted 06-18-2001 12:04 PM ET (US)   Profile for Eagleman   Send Email to Eagleman
Have any menbers ever built or seen a combination rear navigation light and PA horn mount setup. I want to go to a 360 degree stern navigation light and eliminate the navigation light pole that is currently located in the console of my 22 Outrage. At the same time I want to set up a PA horn that is hooked up to a new Standard Horizon VHF radio with PA and fog horn warnings. I would like to use the existing stern light block as the base point for installation.Thanks Eagleman
Tom W Clark posted 06-18-2001 01:18 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
The stern light pole seems like an odd place for a PA horn but what the hell, why not.
I built a new stern light for my Outrage by finding a piece of stainless steel tubing (ornamental, i.e. thin wall & polished) the same diameter as the existing stern light. You need only notch the bottom lip of the tubing to fit over the indexing pin in the base and drill a hole for the wire grommet to snap into. I used an all around (360) white light very similar to the 135 stern light that was standard equipment.
I imagine you would clamp your PA horn to the tubing below the light and feed the wiring for it inside the tubing just like the light wiring.
I suggest you make the stern light pole as long as possible and still be able to stow it in the under gunwale rod racks.
