Topic: Sonar Change, will old bracket work?
66Sakonnet |
posted 06-22-2001 08:37 AM ET (US)
I'm moving from a Lowrance 1240 to a humminbird 100, I'm praying that the humminbird transducer will fit the bracket for the lowrance, has anyone made this change before that can offer some insight...thanks
Whaletosh
posted 06-22-2001 09:25 AM ET (US)
I haven't but you should be able to use at least one of the mounting hole. If the new backet covers the second hole, just fill it with 3M 5200. If not fill, clean it up good and then fill it with MarineTek or gelcoat repair. |
triblet
posted 06-22-2001 10:26 AM ET (US)
You will have a problem is the holes are close, but not the same. The Humminbird has three screws. It's assume that the Lowrance does too, and you reuse one hole. That's now five holes in a small area.You may be able to install the Humminbird bracket in the Lowrance holes by doing a l little drilling or filing on the new bracket. This would probably be better than making fibreglas look like swiss cheese. BTW, all the current Humminbirds seem to use the same bracket. I upgraded from a real cheap bird to the Wide Panorama 3D, and used the same bracket. Chuck |
Whaletosh
posted 06-24-2001 07:56 AM ET (US)
another option is to get a small piece of 3/4" thick Starboard (marine grade plastic). Drill and countersink it so that you can re-use the holes currently in you transom. Then screw the new transudcer bracket to the Starboard using 3/4" SS screws. You will need to seal the screws that hold the Starboard to the transom, but not the screws holding the transducer to the Starboard. You will also need to pre-drill the Starboard for the mounting screws for the transducer, use a 9/64" or #23 drill for #10 screws. Do this before you permantantly mount the Starboard to the transom or make sure you don't drill deeper than 3/4"; you don't want to drill into the transom. that would negate the purpose of using the Starboard. You can get Starboard at West Marine or Boat/US and other stores. Or if you measure waht you need I can send you a small piece, I have lots of scraps laying around. Let me know. |
