posted 06-27-2001 10:23 PM ET (US)
I dont think your bimini will be usable, but then, you wont need it if you have a T-top. High quality tops run from 2 to 3 thousand dollars. Decent quality, but designed for easy fabrication, from 1 to 2 thousand. If you want to keep your bimini, perhaps an Arch? See lhg's boat for a great example. I just finished rewireing my whole boat, and if yours is a vintage model, I can't see the benifit of putting the battery in the console. Streaching about 10 feet from motor to battery (proably 15 in actual cable) with 2 gauge would be a pain. Dive 1 put his under the rear seat. Mine are in the side wells. I ran black and red 6 gauge, connected to the battery through a 70 amp breaker (blue sea systems) on positive, and a 500 amp shunt (heart interface link 10 battery monitor, nice unit) on negative. Then attach positive to blue sea systems waterproof panel, and neg to bus bar. Wired the outputs from the panel to another bus bar. Now to connect anything, just patch to pos and neg bus for appropriate breaker.
This is a relitvly easy job, but time consuming to do it right. You have to crimp, thne solder, then shrink wrap every connection. Be very carefull of how you run the cables: if they chafe while underway, you at a minimum will strand yourself. I dont want to think about the other extreme. My entire system took me about three days, but I was doing some other stuff as well.
Cost? Man, I dont even look anymore, but I'd guess wire = 300, terminals = 50, various crimpers = 100, link 10 = 230, blue sea systems panel = 110, and add 200 for "stuff"
Larry
