  trolling motor mount
Author Topic:   trolling motor mount
JFM posted 07-12-2001 03:39 PM ET (US)   Profile for JFM   Send Email to JFM
Does anyone know of a trolling motor mount available for a 13 sport that can be clamped to the hull? With the cable and pully steering I don't think it's wise to use a helm mounted trolling motor. Thanks, Jay
Bigshot posted 07-12-2001 03:58 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
Buy a trolling motor that has the clamps and steers like an outboard. Clamp it to the transom on the port side I believe. Newer ones(tan) have an indentation where it goes. Does not make a big dif cause it has no torque per say and is not going to screw itself off. Minnikota makes them for like $100. Plenty to push a 13.
JFM posted 07-12-2001 04:00 PM ET (US)     Profile for JFM  Send Email to JFM
My mistake on trolling motor mount. I should have said transom mount instead of helm mount. Jay
JFM posted 07-12-2001 04:05 PM ET (US)     Profile for JFM  Send Email to JFM
Bigshot, I think with the transom mount unit it may interfere with the cable steering. Jay
Bigshot posted 07-12-2001 04:22 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
Nah! you can adjust the height of the head unit to clear and I doubt those clamps stick out that far. You can also mount that one to the bow I believe. Then again what the hell do I know. Somebody here must have experience. I thought you meant the one that attaches to the lower unit with extra weight etc. Sorry!
JFM posted 07-12-2001 04:50 PM ET (US)     Profile for JFM  Send Email to JFM
Bigshot, part of my poblem also deals with weight. I have a 1990 40HP erude, a battery,a 12 gal tank, and I go about 225, all behind the helm. I'm worried if I put a trolling motor with another battery back there I may sink a Whaler.
Samars posted 07-12-2001 05:06 PM ET (US)     Profile for Samars  Send Email to Samars
I have been looking for a trolling motor for my 67 13 BW also and hoped this topic came up...a fairly inexpensive transom mount unit ($150-200)30-40 thrust should do the job. The motor is an Evinrude and has cable steering...I wouldnt expect there to be a problem with placement? Before I buy...can anyone clear this up...
Dick posted 07-12-2001 08:36 PM ET (US)     Profile for Dick  Send Email to Dick
I am running a 52# thrust bow mount on my Montauk and it is plenty. I would think that something in the 30 to 40 # range would work fine. The motors don't weigh much but when you add a good GP27 deep cycle to power it the pounds start to add up.
Dick
Eric posted 07-13-2001 12:10 AM ET (US)     Profile for Eric  Send Email to Eric
On the montauk, did you install a scissors type bow mount motor, or fabricate a bracket for a stern mount? What kind of motor?
JFM posted 07-14-2001 10:10 AM ET (US)     Profile for JFM  Send Email to JFM
Samars. I have just tried to install the Minkota Endura transom mount 34# thrust to my 1972 13 sport. The mount for the trolling motor did not work with the cable steering system. I am going to try the old 30# Endura and if that doesn't work I will try to make a mount for the bow. Regards, Jay
Dick posted 07-14-2001 10:58 AM ET (US)     Profile for Dick  Send Email to Dick
Eric
I used a Motorguide 552V Magnum+ with tiller handle steering. It is the sissor mount with the addition of the Motorguide removable system.
Dick
Tsuriki BW posted 07-14-2001 11:54 AM ET (US)     Profile for Tsuriki BW  Send Email to Tsuriki BW
I have a Minn Kota Enduro 44 mounted on the stern, trolling bracket, and a Minn Kota Maxum bow mount on my Dauntless 14. Battery is located inside the CC. Electrics are really nice.
Find the right size, best place for battery mount and you will enjoy it very much.
Tsuriki
Samars posted 07-15-2001 08:05 PM ET (US)     Profile for Samars  Send Email to Samars
Ok, thanks all...What do I need in addition to the electric motor so that I can mount it on the bow...? does anyone have pictures for a bow mounted trolling motor on a 13 BW
Tsuriki BW posted 07-15-2001 08:41 PM ET (US)     Profile for Tsuriki BW  Send Email to Tsuriki BW
Samars. I just e.mailed you a pic of a Minn Kota 44lb foot controlled trolling motor bow mounted on my Dauntless 14.
Hope it helps.
Tsuriki
Dick posted 07-15-2001 09:16 PM ET (US)     Profile for Dick  Send Email to Dick
Samars
I am e mailing you the pics of my Montauk and the Motorguide bow mount.
Dick
JFM posted 07-16-2001 09:36 AM ET (US)     Profile for JFM  Send Email to JFM
Samars , I tried a Motorguide 36# on the transom with a modified teak peice to hold the bracket higher . It seemed like it would work, however when I tightened the nuts I cracked the inside transom gelcoat. I am going to make a custom mount for the bow out of stainless that mounts to the bow using U bolts so I don't have to go through the hull . Regards, Jay
Samars posted 07-17-2001 08:11 AM ET (US)     Profile for Samars  Send Email to Samars
Thanks Jay...if you have pictures of the modification...can you forward them to me. I also do not want to screw or drill into the bow....
