posted 07-30-2001 10:33 PM ET (US)
Sinclair7,Typically the rule is:
epoxy over poly = yes
poly over epoxy = no
That said, you can indeed put gelcoat over epoxy, with adequate prep.
That washing and sanding you read about was in refrence to something called "Amine blush" which is a residue that forms on the top of curred epoxy, usually when humidity is high/changing. In genneral, epoxy created a much stronger secondary bond than does poly, thus the rule above. However, if you wash your epoxy work, then dry, then sand it, the gelcoat will stick. You wash it to get rid of the amine blush film, which prevents you from sanding it back into the epoxy.
I always wipe anything I'm going to use epoxy and/or poly on with acetone about 15-30 min before applying. Keep the rag clean, exposing new surface often. Use lots of rags for a big area. Work in a well ventilated area. Make sure the temperature is good, and not on the downfall. Same for humidity.
Read the Evercoat can to see what it is. Its proably poly. As for the gelcoat being clear, I can't answer for that, as they are usually white, which provides a base for tinting. Perhaps you should stir it, the pigment might be on the bottom of the can. If it is, then check for dates on the can, as the shelf life of this stuff is not great.
Hope this helps. Larry
