Topic: Bow Light wiring for 13' Sport
root |
posted 08-06-2001 06:06 PM ET (US)
I have a late 80's 13' Sport Whaler. The previous owner really fudged up the wiring under the bow light, and now I'm stuck with having to cut out a section of Fiberglass to get to whats left of the wires, patch them with some new wire and patch the fiberglass. This has turned into a serious ordeal. Do any of you guys have a diagram of how the wires run inside the hull? What is the professional way to change that wire, there is ZERO slack on it, so I can't figure out how to "re-thread" it.I guess most of all I'd just like to hear about other peoples experiences with this subject, and a Wiring Diagram. Thanks, root.
Dick
posted 08-06-2001 06:30 PM ET (US)
The wires are run down the side of the boat under the starboard rubrail. |
Bigshot
posted 08-07-2001 10:48 AM ET (US)
Personally I would leave the old wires there and rewire 2 new ones up the rubrail. You can drill a small hole under the bow to insert them if they were to be exposed. Will look factory and no fiberglass work. Forget the old stuff. |
Tom W Clark
posted 08-07-2001 10:57 AM ET (US)
root,Don't cut any fiberglass! If your boat is from the late eighties (or any thing after the early 70's, for that matter) the wires do not go through the hull. As Dick points out, they are led under the rub rail insert. Simply peel the black insert out of the receiver to the bow on the Starboard side and you will see the wire. Pull it out and replace it with new. This wire goes from the terminal block in the stern near the stern light mount to the bow penetrating the hull only at those two places. No need to cut, drill or dig, just poke the new wire through the old holes and you will be on your way in no time. |
root
posted 08-07-2001 12:45 PM ET (US)
Thanks everyone!I wish I hadn't cut as much fiberglass as I allready have!!! (It's really only 2 square inches infront of the Bowlight, but a little deep too). Anyway, I'm going to take off the rub rail, but I looked under a strip of the rail and didn't see any sign of wires running down the starboard side. I'm going to investigate further after work and I will post more. Thanks, root. |
TIMMY
posted 08-07-2001 09:35 PM ET (US)
I HAD THE SAME PROBLEM WITH RECENTLY PURCHASED 13 SPORT 1986.I WAS LUCKY TO HAVE A SHORT PEICE OF WIRE STICKING THRU THE REAR HOLE. SO I JUST LENGTHENED THE WIRES. NOW YOU QUESTION HAS ANSWERED A QUESTION FOR ME I THOUGHT THERE WAS A FUSE BOX FOR THE LIGHTS SOMEONE SAID THERE WAS A TERMINAL BLOCK. |
