  1998 BW RAGE 15 jet Help..?
Author Topic:   1998 BW RAGE 15 jet Help..?
lostcode posted 08-10-2001 06:23 AM ET (US)   Profile for lostcode   Send Email to lostcode
i keep getting a high temperature and i checked the intake to make sure is clear of any debris or obstruction. but after a couple of minutes the engine temperature starts to rise again above normal.
?? can anyboade suggest what i should do next?
Bigshot posted 08-10-2001 12:56 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
Performance the same? Check thermostat?
mjd65 posted 08-10-2001 01:21 PM ET (US)     Profile for mjd65  Send Email to mjd65
You want to check the tell tale to make sure the water is flowing. If it has the OMC 115 it will be located at the top of the impellor housing. You may have sucked up mud or silt? If you have floor it in neutral and it may blow it out. Also if it has an intake water filter check and make sure that the screen is clear. But befor that check and make sure you have no ropes, fishing line, plastic can hoders or any other foriegn debris caught in the impeller. Your may have to slide the housing back to check this.
Good Luck
Lake Breeze Rage
lostcode posted 08-11-2001 08:09 AM ET (US)     Profile for lostcode  Send Email to lostcode
thanks ....
mjd65 posted 08-13-2001 01:52 AM ET (US)     Profile for mjd65  Send Email to mjd65
So how is it working? And what worked?
Lake Breeze Rage
lostcode posted 08-14-2001 02:05 PM ET (US)     Profile for lostcode  Send Email to lostcode
54 mph
it flies with that mercury 175 hp engine
it was some trash on the intake
