  swim platform repair
Author Topic:   swim platform repair
Jersey Jim posted 08-13-2001 07:31 AM ET (US)   Profile for Jersey Jim   Send Email to Jersey Jim
New montauk came equipped with swim platform. Platform has a handrail on one side that screws into the transom with a #14 screw 1 1/2 long. The screw has pulled out.
I assume there is wood behind the screw. I thought about replacing the screw with a 5/16 lag bolt or maybe a thru-bolt. Or should I epoxy the hole and use the same screw ? Thanks for the help.
gunnelgrabber posted 08-13-2001 09:12 AM ET (US)     Profile for gunnelgrabber  Send Email to gunnelgrabber
jim, ..i have one that's probably similiar. the top ones are bolted through the (wood) transom, 1/4" stainless..i check them for any looseness. the bottom ones are a special case in that there's nothing there.(look at triblet's recipe and other posts on the subject in order to really do it right).can't imagine it coming loose. good luck...lm
