  Mills Bimini Top
Author Topic:   Mills Bimini Top
PDM posted 08-13-2001 09:07 AM ET (US)   Profile for PDM
Does anyone know if you can adjust a Mills bimini top to make it higher? My bimini top is about about 5' 8" above the deck unfortunately my head is 5' 11" above the deck which creates a conflict. My head usually loses. I looked at the frame and it appears to be adjustable, however the screws that hold the thing together are either torx or allen screws and I don't want to mess around with it if its not meant to be adjusted. Has anyone adjusted a Mills bimini top to make it higher? Any advise is appreciated.
Paul
compounder posted 08-13-2001 09:45 AM ET (US)     Profile for compounder  Send Email to compounder
Probably the easiest way to raise the top is to raise the mounting area. Just add more,or larger, teak, mahogany, or starboard blocks at the hull mounting point.
andygere posted 08-13-2001 11:15 AM ET (US)     Profile for andygere  Send Email to andygere
I think Chuck may have researched this with Mills. Take a look at earlier posts.
