  How to lube deck plate O-rings?
Author Topic:   How to lube deck plate O-rings?
commodore posted 08-15-2001 04:42 PM ET (US)   Profile for commodore   Send Email to commodore
I know I've read it somehere on this site, but what is a safe lube for the rubber o-rings under the deck plates on an 18' Outrage?
Thanks
Tom W Clark posted 08-15-2001 07:04 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Just about anything. Vaseline, bearing grease, lithium grease.
Use something heavy and waterproof. Clean up any and all that squeezes out after pressing in the deck plate.
triblet posted 08-16-2001 02:25 AM ET (US)     Profile for triblet  Send Email to triblet
Tom is right that darn near anything will
work. The HW store should have something
called plumber's grease that should be
pretty good. I use it on the big O-rings
on my pool and hot tub pumps.
The perfect stuff is probably Dow-Corning
111. It's made for lubing valves and won't
wash away. http://www.mcmaster.com/
and search on Dow-Corning paste. About $10
for enough to last you a lifetime. Also good
for electrical connections on a boat.
Whatever you use, you don't need much on an
o-ring. Just enough to make it shiny and
slippery, not enough that you can see any
thickness anywhere. The grease doesn't keep
the water out, it just keeps the o-ring from
deforming due to friction as things go
together.
O-ring greasing is a ritual for us UW
photographers. It's how we worship the
gods Nikon and Neptune, and keep them from
ever meeting. ;-)
Chuck.
Kim posted 08-19-2001 11:50 AM ET (US)     Profile for Kim  Send Email to Kim
on my pool pump I use a pure Silicone this DOSE NOT wash off.
rainbow plastics
El Monte. ca.
it comes in a very small bottle (3/4oz) but goes a long way. never sticks and holds under preasure as on the pool pump. any pool suply should have this or can get it for you. this is the kind.
kim.
Kim posted 08-19-2001 11:52 AM ET (US)     Profile for Kim  Send Email to Kim
on my pool pump I use a pure Silicone this DOSE NOT wash off the O ring
rainbow plastics
El Monte. ca.
kim.
Kim posted 08-19-2001 11:55 AM ET (US)     Profile for Kim  Send Email to Kim
sorry about the dbl. post.
I forgot to say, the bottle reads
Silicone
"O" ring lubicant
