  Sandable primer?
Author Topic:   Sandable primer?
specktrout posted 08-15-2001 11:45 PM ET (US)   Profile for specktrout   Send Email to specktrout
Thanks again for all of the great help regarding my request for information on painting my outboard. I bought the Tempo zinc chromate primer and the matching topcoat in johnson white. However, my local marine store doesn't seem to have sandable primer in a spray can. Should I just use one of the sandable auto primers or is there a prefered product anyone has? Thanks again.
bigz posted 08-16-2001 06:45 AM ET (US)     Profile for bigz
You have your "sandable" primer Spectrout it is the zinc chromate! Use this right on the motor as the primer you can sand this after it is dry (should try for at least 2 coats, 3 to 4 is better).
I noticed I goofed in the other post on the last part of finishing. It should read 48 hours not 24 after the last coats are sprayed before compounding. Good luck -- Tom
PS oops didn't realize your using white finish paint, suggest you use the yellow zinc easier to cover than the green zinc.
LarrySherman posted 08-16-2001 07:35 AM ET (US)     Profile for LarrySherman  Send Email to LarrySherman
Yup, don't woory about the sandable primer, if youv'e prepped the motor well, you won't need to sand. I'd go ahead and use the green since you have it. I used it and the Johnson white top coat covered it very well.
PS: Wear a mask!
