Topic: Trailer Bearings
Caceman |
posted 08-26-2001 02:28 PM ET (US)
Can anybody point me to a good resource on how to remove/install and grease trailer bearings? Thanks.-Andrew
whalerron
posted 08-28-2001 05:31 PM ET (US)
Try this article. It refers to repacking bearings on a car but it is identical to doing it on a trailer.http://www.autoweb.lycos.com/garage/subsys/bawheelb.htm |
Dr T
posted 08-28-2001 06:30 PM ET (US)
There are also exploded drawings and text on the web pages for Bearing Buddy (www.bearingbuddy.com) and Trailer Buddy (www.ufpnet.com) that address some unique problems associated with boat trailers.When I repacked my bearings last weekend, I used brake degreaser to clean the hubs. Basically, they go back together the same way they come appart. You will need a Hammer, pliers, a big wrench, a punch, and a screw driver. Four Tips 1. Make sure you use a marine grade grease 2. Make sure the bearings are greased before you install (very messy, but worth while) 3. Pack the entire hub with grease before you install. 4. Use a Bearing Buddy or similar bearing protector. |
whalerron
posted 08-28-2001 10:22 PM ET (US)
If you are not using a spring loaded dust cap like a Bearing buddy, DO NOT pack the hub with grease. Instead, put a layer of grease in the hub that is between 1/8 and 1/4 inch think. You must leave some space for air. If you don't the grease will expand from heat and it will pop out the inner bearing seals. |
Dr T
posted 08-28-2001 11:07 PM ET (US)
Agree. My items 3 and 4 have to go together. |
Dr T
posted 08-29-2001 09:53 AM ET (US)
Forgot to add: If you use regular hubcaps, instead of bearing buddies, and do not fill the hubs completely full of grease, this will lead to bearing failure much more rapidly. As was pointed out, hubs heat up as they turn. and this causes the air inside to expand. When you back the trailer down into water, the assembly cools rapidly. This creates a vacuum that will suck the water inside the hub assembly. Even if you use a marine grade of grease, this standing water will ultimately find its way to the bearings and races, causing them to rust and fail. |
triblet
posted 08-29-2001 09:57 AM ET (US)
And to do it right, you'll also need a torque wrench with a real low range. The nut is very lightly torqued. Mine is 20 INCH pounds. I had to special order the torque wrench.Packing the wheel bearings is a lot quicker with a packing tool. Any big autoparts store will have them. It's not terribly difficult, just a bit messy and time consuming. Bearing Buddies come in stainless and plated. If your trailer will ever see salt water, get the stainless. They are only a couple of bucks more. Chuck Chuck |
Dr T
posted 08-29-2001 04:22 PM ET (US)
Chuck,I have wondered how you do that. My spindles have one hole for the cotter pin. The castle nuts seem to only give me three choices: Way too loose (not even finger tight), a middle position, and obviously too tight. I have just taken the one in the middle. Is there a better way? tds |
Dick
posted 08-29-2001 08:26 PM ET (US)
Easy and cheap way to take the mess out of packing bearings is a pair of latex surgical gloves. They are also great in the shop for painting and staining. |
triblet
posted 08-30-2001 10:19 AM ET (US)
Dr. T, you are probably about right. I torque the nut, spin the hub a bunch, torque again, repeat several times. Now loosen a touch and torque again. Now it's decision time. If just a little tighter will make the holes line up, tighten. Otherwise, loosen. Put the pin in. It's worth seeing what the torque is like just grabbing the nut and hand tightening it in case you ever have to do it in the field and don't have the torque wrench. I keep a cheap beam torque wrench in the hub kit I keep in the truck. Chuck |
Dr T
posted 08-30-2001 12:50 PM ET (US)
Chuck,Thanks for the gory details. I use the same technique, sans the torque wrench. (I keep an oversized vice grip with the hex head and a f vice grip with needle nose in my pickup to work on mine. The big one doubles as a hammer in an emergency). Perhaps if I had a big, heavy boat like your Montauk I would get the torque wrench. Given the white hair my bearings have cost me over the last month, all I can say is that I am glad that the 13 is a light boat. Terry |
smo
posted 08-31-2001 11:46 AM ET (US)
Here's a great discussion on how bearings fail and what people do wrong with "Bearing Buddies" that makes them fail:http://users.westco.net/~tandjlm/Information/describe.htm |
triblet
posted 08-31-2001 06:46 PM ET (US)
The fundamental problem there is the squirt of grease into the hub every trip. Only add grease if it needs it. You can tell by rocking the piston assembly (the bit with the grease fitting). It should rock about 1/8". If it doesn't, add a little grease and try again. No need for set screws. Chuck
Caceman
posted 09-04-2001 09:28 PM ET (US)
Thanks guys. I think I will have the local shop take care of it this time around. They can put in brand new bearings, etc. This way, I'll know that it was a professional job. My trailering will be between San Antonio and Corpus Christi, TX, about 300 miles roundtrip. I'll be seeing a lot of saltwater, so I definitely plan on getting some Bearing Buddies. -Andrew |
Dr T
posted 09-05-2001 01:40 AM ET (US)
Andrew,I understand your desire for a "professional" job, but let me caution you that you need to be careful. Recently there was a thread in the Performance section ([url]continuouswave.com/ubb/Forum4/HTML/000406.html/url) in which several of us detailed our horror stories. In my case, the "professional" who repacked the bearings put a bearing with a 1.0625 in. inside diameter on a 1 in. spindle. This was not good, especially since I pulled the trailer from San Angelo, Tx to Steamboat Springs, CO and back to Denver. This included 5 major mountain passes and a number of significant grades. I am very lucky that something did not break. So, if you don't want (or don't feel comfortable) doing the job yourself, please CAREFULLY select the guy that is going to do the job for you. You really wouldn't want to lose a wheel half way across the causeway between Corpus Christi and Port Aransas (been there, done that, not fun). Good luck. tds |
Dr T
posted 09-05-2001 01:42 AM ET (US)
Try this link to the "Wheel Falls Off Trailer" thread: http://continuouswave.com/ubb/Forum4/HTML/000406.html |
triblet
posted 09-05-2001 10:37 AM ET (US)
Caceman, boat trailers should have Bearing Buddies even if they only see fresh water.Chuck |
