posted 11-11-2001 09:54 AM ET (US)
It is not unusual for small cracks in the gelcoat layer to occur, but these generally only expose underlying layers of the laminate. Cracks like this do not expose the foam. The color of the underlying material indicates its composition. Bluish-green material is laminate, brownish material is foam.In general, it takes a fairly significant crack in the cockpit to expose the foam.
The strength of the Whaler hull depends on the integrity of the bond between the laminate and the foam. If large areas of the laminiate are debonded from the foam a serious reduction in hull strength will occur. Bonding can be tested by tapping the hull with a small mallet and listening to the sound produced.
The ability of the foam to absorb water has been discussed at length in previous posts. The general summary is that it may be that earlier boats had foam cores that were more prone to absorb water than those of later years.
For example, a boat of similar vintage to yours, my 1976 Whaler 15-Sport, has a light brown foam core that is completely unfinished in the bow locker (the point at which it was originally pored into the hull cavity), and this foam appears to shed water. It shows no sign of any tendency to absorb water and I find it hard to believe that Whaler would have left it unfinished if it represented a portal for water to enter the core.
Water entering the core from the cockpit is much less relentless than from the hull bottom. Unless you run the boat with the cockpit filled with water, I would think the opportunities for water to enter would be limited.
The cure for wet foam is:
--dry it out
--rebond foam to laminate
--repair laminate to prevent more entry
Discussion of this can be found in earlier postings or instructions can be obtained from Whaler Customer Service (or your dealer if they're not some SeaRay Bowrider mousse-in-the-salesmen's-hair bunch).
--jimh
