  What prop for Montauk?
Author Topic:   What prop for Montauk?
mbking1 posted 12-25-2001 11:53 PM ET (US)   Profile for mbking1   Send Email to mbking1
Can anyone give me info as to which pitch alum prop to order for a 90hp four stroke Merc/Yamaha on a Montauk. Fresh water use not too fast. Thanks
FISHNFF posted 12-26-2001 12:06 AM ET (US)     Profile for FISHNFF  Send Email to FISHNFF
There are a few posts to answer your question in the past, but to give you an answer now in one word, seventeen. This will give you good holeshot and keep you in the right part of the RPM range, around 5600 loaded.
maverick posted 12-26-2001 08:50 AM ET (US)     Profile for maverick  Send Email to maverick
I agree. I've had 2 Montauks - each with [new] 90 "2" strokes - a Rude and Johnson. Maybe a bit different than the 4 stroke you mentioned. I ran 13.25 by 17s, and wow, great holeshot, excellent speed, 45-48 WOT. I did run a stainless 13x19 once, and it was a big sluggish out of the hole, but added top end. I preferred the aluminum 13.25x17. Best, Mav
bradenton whaler posted 12-27-2001 11:09 PM ET (US)     Profile for bradenton whaler  Send Email to bradenton whaler
I have a 93' 90HP Johnson that tops off at 35 mph. Is something wrong? I saw the reply of 40 to 45 mph.
FISHNFF posted 12-28-2001 01:16 AM ET (US)     Profile for FISHNFF  Send Email to FISHNFF
Yes, something is wrong. First, how are you measuring your speed? A GPS is the only real accurate way, short of a radar gun. With a clean bottom and trimmed right, you should be in your mid 40's, 40 minimum.
Bigshot posted 12-28-2001 10:06 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
Bradenton FL? #5 is what a 50 will do. You should be running 42-45. What RPM's are you doing?
bradenton whaler posted 12-28-2001 02:28 PM ET (US)     Profile for bradenton whaler  Send Email to bradenton whaler
-Using a GPS to read speed.
-Tachometer is broken. Need new one!
I might get someone to check it out. I had the compression checked when I bought it, the mechanic said it was good.
Thanks.
B'ton, FL
