  Exterior
Author Topic:   Exterior
joem posted 12-28-2001 05:33 PM ET (US)   Profile for joem   Send Email to joem
I need a couple of answers I started sanding the exterior and want to know the precedure. I need to sand and rough everything. Then fill in spots that have bubbles with putty do I need to gel-coat all exposed or puttied spots and then prime and paint.
I have heard from the boat store that with the new paint systems I don't need to gel-coat over the spots with bubbles after I have repaired them. I guess that is my question I am a little confused about what to do I need a little help.
joem
JohnAz posted 12-28-2001 06:23 PM ET (US)     Profile for JohnAz  Send Email to JohnAz
I hope you are not using "putty" Marine Tex or similar epoxy based filler is what i am hoping you mean,,,,
joem posted 12-28-2001 06:58 PM ET (US)     Profile for joem  Send Email to joem
I am using a resin and fiberglass based putty I add a catalyst to. I have purchased for mini-craft in florida. Mini-craft calls it their reinforced "A" putty.
joem
joem posted 12-30-2001 03:51 PM ET (US)     Profile for joem  Send Email to joem
Could someone please help with this topic. I would really appriaciate it. I am getting two different messages one from the forum and one from the store. I need clarification in this matter.
joem
DIVE 1 posted 12-30-2001 08:30 PM ET (US)     Profile for DIVE 1
Joem,
If you are going to prime and paint with a 2-part marine paint like Awlgrip, then you do not need to gelcoat at all. Decide on the paint first and then follow the manufacturers instructions for filling and sanding.
Jim
joem posted 01-03-2002 08:21 PM ET (US)     Profile for joem  Send Email to joem
I talked to the Area rep. for awlgrip? I was told that if I was to use the system that they have 1st. it is very expensive and 2nd. if I was ever to leave the boat in the water for any lenght of time that all the paint could peel or blister is this true.
I then called a local repair and paint dealer and proceeded to ask a bunch of question and was told the only way to do a proper job was to regel-coat is this true are these my only 2 options? Do I have any other way of repainting the sides and bottom of my boat???
joe
Outraged posted 01-04-2002 09:17 AM ET (US)     Profile for Outraged  Send Email to Outraged
You might also want to check into the Interlux products that are avaiable, which should be less in price than Awlgrip.
Outraged
dburton posted 01-04-2002 01:40 PM ET (US)     Profile for dburton  Send Email to dburton
Two part poly pant such as Interlux, Sterling or Awlgrip will blister if they are used below the water line and the boat is left in water for any length of time. On a trailer boat this is usually not a problem. A few days or a week in the water is not likely to cause blisters. All of these paints are sold for use above the water line. All of these suppliers recommend their own brand of bottom paint to be used as part of their system. That is, two part above the water line and bottom paint below the water line.
I am going to paint my 1976 -13 sport with two part above and below the water line. It will be rare that I will keep it in the water for more than 48 hours. I will be able to report back in a year or so if it was a good or bad idea.
Doug
JFM posted 01-04-2002 04:20 PM ET (US)     Profile for JFM  Send Email to JFM
Joem, another choice widley used on damaged glass through the gel coat is West Systems epoxy. It's a 2 part system that is good for repairs to the blue color or through the glass. When dry it can be sanded and then wet sanded before painting for a nice finish. Awlgrip is great for above the water line or trailered boat. But if docked for extended time Interlux bottom paint is best. Hope this helps.Regards, Jay
noswah posted 01-04-2002 04:20 PM ET (US)     Profile for noswah  Send Email to noswah
Joem,
If you go to Cetacea, page 41 and scroll to the bottom pictures you will see Rex Bettis's Montauk. I have seen this boat in person and I can tell you it's the best looking Montauk I have ever seen, bar none.
This boat was awlgriped inside and out. I can tell you that this boat even looks better in person. You can't see the detail and quality of workmanship, but real craftsman worked on this boat.
