posted 01-21-2002 01:09 AM ET (US)
Consider a smaller engine. 40hp's are pretty heavy. 50's aren't Coast guard legal on a 13. (but don't let that stop ya ;) ....get some "40hp"decals.
Standing out over the stern on a platform is a whole bunch of weight, but if you're polling, someone's up front fishing so should even it out some.
I've gutted my 13. it is a salvage hull so I didn't feel bad doing it.. It now has:*carpeted front casting deck (with storage under, removeable seat pedistal and an electric motor mount)
*small center console like a flats boat(standing is a helluva lot more comfy in rough water. Integral front seat for a passenger, storage and battery under).
*rear drivers seat/deck that is carpeted plywood, about 18" deep and is as wide as the boat, screwed into the top of the gunnels. Starting battery and fuel tank secured under. Also removable downrigger
My brother says all it needs is the fuzzy dice! Mine polls ok from the "inboard" Platform.
This is a thought as well....if you put a polling platform over the engine you will pretty much need power tilt for convenience....everytime you pull up to a a flat the engine must be raised. Hereagain, weight for the power tilt unit must be added in to the equation...(you + engine+ power tilt unit+ platform= 3 inches of freeboard in the back) Here comes a wave....
