posted 01-26-2002 02:54 PM ET (US)
Russ,I think it is amazing that you have been able to keep the same can of generic wax you bought in 1978 going with all of that polishing you do...
But, in answer to your question. Yes you need to re caulk the seams. If you don't your inner hull will get full of detritus and eventually get into the foam. Just use that tube of caul you picked up from the dumpster of that construction site and you should be fine...
But seriously, use a good quality silicone sealant. I used 101 and it took weeks to cure, meanwhile loading with every bit of dust and sand imagineable.
Now, what to do about all that blistering....
Your respectfull nephew,
Brian
