  Replacing encapsulated wood
Author Topic:   Replacing encapsulated wood
Moby posted 02-12-2002 10:20 PM ET (US)   Profile for Moby   Send Email to Moby
I recently noticed brown stains coming from underneath the side rail mounting points on the "inside ledge" of my '77 Montauk. I found a place where the fiberglass had been damaged, and water had gotten into the wood backing. The wood was destroyed. I cut several pieces of the glass skin away from the wood (on the top surface) and removed the what was left of the wood with a scraper and shop vac. From what I can tell, the wood chamber is surrounded by fiberglass, so there shouldn't be too much water in the foam. I plan to use pieces of Starboard to replace the wood, but thought that I'd try to get some expert advice. Is Starboard what I should use? Should I fill the voids around the Starboard with West System, or should I try to use some type of foam? Thanks for the help.
-tc
JBCornwell posted 02-12-2002 11:11 PM ET (US)     Profile for JBCornwell  Send Email to JBCornwell
Don't use Starboard, Moby. Use Whaleboard. It holds screws much better and it is what BW now uses in that spot.
Red sky at night. . .
JB :)
Duncan posted 02-13-2002 12:17 PM ET (US)     Profile for Duncan  Send Email to Duncan
Marine-tex maybe? Says it can be drilled and tapped.
kamml posted 02-14-2002 07:32 AM ET (US)     Profile for kamml  Send Email to kamml
I have had the same problem with brown staining coming from the upper holes on the rear railing mounting points of my 77 Montauk. I thought I would try Git-Rot liquid in the holes first before attempting plastic surgery. Is that worth a try? Ken
Moby posted 02-14-2002 10:20 PM ET (US)     Profile for Moby  Send Email to Moby
I didn't realize that there was a difference between Starboard and Whalerboard. Where can I get more info on Whalerboard?
JBCornwell posted 02-14-2002 11:43 PM ET (US)     Profile for JBCornwell  Send Email to JBCornwell
Hi again, Moby.
Email: tami@richlite.com
Tell her what you want to do and ask for a sample or two.
I used Whaleboard to plug drilled out screw holes; drilled and tapped them and remounted my rails with machine screws. SOLID!
JB :)
