ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Storage in a Montauk
Author | Topic: Storage in a Montauk |
Denny |
posted 03-05-2002 02:25 PM ET (US)
Looking at my Montauk and thinking about storage I started to wonder if you folks out there have come up with any unique ways of getting more storage for gear in the boat. A buddy of mine suggested a 8 man raft, a tow rope, and a sign that says “ I buy fishing tackle” I’ve figured out that a bigger cooler would help but I am looking for more ideas. Thanks, |
Bigshot |
posted 03-05-2002 02:53 PM ET (US)
Get a P.O.D. and stick it in the stern. When you need it, just call and they will deliver. When done they remove and store. Not sure if it will fit but would also double as a hotel room. |
JBCornwell |
posted 03-05-2002 05:58 PM ET (US)
Ahoy, Denny. One of the things I liked about my Sakonnet better than my Montauk was the front casting deck. One could store a lot under there. I have also seen custom raised rear decks that did the same. I was lusting through my newly acquired '76 Whaler brochure today and came upon the optional raised front deck for the Montauk. It looks SO good with the teak hatch covers, and it would probably balance the boat better with that wonderful Suzi DF70 on the transom. (Sigh!) Red sky at night. . . |
Chesapeake |
posted 03-05-2002 06:42 PM ET (US)
JB: Can you please describe it, e-mail or fax a picture? I have been toying with the idea of building something like this for my Nauset. Bob |
Dick E |
posted 03-05-2002 07:43 PM ET (US)
Go to Cetacea Page 53 for some pictures |
Denny |
posted 03-05-2002 10:04 PM ET (US)
You are right about how that raised deck looks---Wow! That looks good. It seems that it would not be too difficult to duplicate. The pictures show quite a bit of information. The bracing under the deck would be something to check out. Thanks for the referral. If I were to get a POD would it require more than one whaler? i.e. a pod of killer whales. Denny |
JBCornwell |
posted 03-05-2002 10:39 PM ET (US)
Ahoy, Chesepeake, Denny. The custom deck on the Nauset in Cetacea certainly is handsome. It reminds me of the painted pine deck on my Sakonnet, but much more elegant. I have been deferring learning how to post photos, though I do know how to Email them. I will attempt to post the photos of the OEM Montauk with front deck and the Sakonnet with front deck from the brochure. I have to crank up my slow scanner, so look for them tomorrow. JimH: Does that present a problem? Red sky at night. . . |
Whalerdan |
posted 03-06-2002 08:17 AM ET (US)
I've thought about this problem on mine from time to time. I got the idea to put some shelves (one, maybe two) in the console. You could access them through the port side door. Haven't done it yet though. I never put anything in there that is tall enough to utilize that space properly. |
triblet |
posted 03-06-2002 09:56 AM ET (US)
I've thought about shelves in the console of my Montauk, but for right now, I've just got three medium size Pelicans, two smaller ones, cloth bag with jackets and spare gloves, and a CellSafe for the Nokia. I've been thinking about bolting a bicycle
triblet |
posted 03-06-2002 09:58 AM ET (US)
One more thing: I clip the bag with the PFDs to side rail. It's inside the boat when under way, flipped outside when at anchor on the dive spot. It makes a huge difference in deck space. Chuck |
Bigshot |
posted 03-06-2002 10:07 AM ET (US)
Benn many discussions on the factory casting platforms on Montauks. I had one on my 1977 and I took it out and sold it. Looks like a lot of storage but it isn't and makes using the cooler as a seat impossible due to blockage of vision. It is also heave and we all know what weight in front of a montauk does in chop. If you guys are serious...build one out of wood that is easily removed and cutout to fit cooler. |
OutrageMan |
posted 03-06-2002 10:54 AM ET (US)
My father has come up with some interesting storage devices for his Montauk. The first is a cubby in the top of the console. Using a "Bekson Plate" he cut a hole to fit the plate through the top of the console and fit the plate in. From underneath he mated a rubbermaid container and sealed it to the flange of the plate. It makes a very handy place to put wallet, keys, etc. The second is a system using 2 24 qt (I think)coolers in the aft section of the boat. Both have seatin cushions. On one he drilled and sealed several holes. In some of these he installed little disks with fins on them to act as ventilation. On another, larger hole, hit fitted a rubber boot. Inside the cooler he place his oil resivoir, and battery. He then ran the cables and tubing through the hole with the rubber boot. He left the other cooler empty for misc. storage. Having the coolers in the aft quarter also gives a stern seating option with the cushions. Brian |
Tom W Clark |
posted 03-06-2002 11:33 AM ET (US)
Denny, If you're having trouble stowing all your gear then maybe it's time for a bigger boat. But seriously, The key to having everything stowed is not to fall into the trap of feeling like you need to bring everything except the kitchen sink every time you go boating. I got along quite nicely in my last Montauk (which was typically salmon fishing with 2 to 4 adults on board) This is how I stowed stuff: For starters the battery was in the stern where it belongs, thus the console was available via 2 doors to store the like jackets and coffee thermos as well as hats, gloves, some fishing tackle items. In front of the console I had the usual cushioned 86 quart Igloo cooler with both a deep tray and a shallow tray. In the bottom of the cooler I had the first aid kit, hand held spot light, flare kit, binoculars (which typically resided on top of the console or in the console during an outing). I kept the boats papers in the canister for the flares so they would be safe and dry. In the deep bin in the cooler I kept miscellaneous lines, my mooring painter, extra dock lines and on top of this relatively soft pile I placed the fish finder when it was removed and being transported to and from the boat. In the shallow bin I had a 3/16" slotted screw driver, a #2 Phillips screw driver, a pair of adjustable pliers, needle nose pliers, emergency radio antenna, down rigger releases, LORAN coordinates and notes recorded in a small note pad, a pen, 2 filet knives, spray nozzle for a hose, a small plastic divided container with miscellaneous screws, cotter pins, fuses, ect., a bungee cord or two, a bait cutting board and a spare drain plug. In the RPS back I stowed the fish club, stainless steel hook remover, a soap container with a bar of pumice hand soap, some small miscellaneous lines coiled up. The tackle box just sat in the back of the boat with the battery boxes for the VRO tank and the battery. Personal gear that came on board with guests was usually stowed in the console or in the cooler. The forward locker had a few bags of ice if we were fishing and this is where the catch went, draining overboard. The paddle was tucked into one side rail and the telescoping boat hook was in the other. Mooring lines, fore and aft were left attached to their respective lifting eyes, coiled and ready to go at a moments notice. I kept two fenders permanently tied to the stanchions of the port side rail because the kicker was mounted to starboard. If I felt the need for fenders to starboard I just moved them over rather than haul an extra pair around. Storage space issues arise in many facets of our lives. I often consult with clients about houses they own or are considering buying. They almost invariably lament: “It’s a great house. We just need a little more space for our stuff...” My advice: Get rid of some stuff or buy something bigger. Don’t try to make a Montauk into something it’s not. |
seagull |
posted 03-06-2002 03:01 PM ET (US)
Took these pics of a Montauk stern compartment that looks to be made out of starboard. |
seagull |
posted 03-06-2002 04:07 PM ET (US)
The compartment opens towards the front with a piano hinge the full lenght. Didn't open it up to look at the substructure, but relized after looking at the pics there must be something under that seat. |
Denny |
posted 03-06-2002 04:34 PM ET (US)
Thanks for the input folks. There are some realy great ideas here. (I like the bigger boat thing) For what it is worth, I've picked up a couple of small back packs and plastic tied them to the port and starboard stern rails. They have waterproof covers and make good storage places for rain gear etc. For unloading just cut the tie and your ready to go. |
triblet |
posted 03-06-2002 09:37 PM ET (US)
Denny, there are removeable zip ties. I can get lightweight ones (about 1/8" wide) at the hardware store, heavier ones (3/8") from http://www.mcmelectronics.com/ and some real serious ones (1/2"+ from my buddy Big Paul). Chuck |
Pops |
posted 03-07-2002 08:28 AM ET (US)
Tom, I liked your detailed description of storage on your Montauk, I was wandering where you kept the anchor? Pops |
Guts |
posted 03-07-2002 08:49 AM ET (US)
Denny I use a velcro typ bag on the rail. these bags are used for walkers (sold at a medical supply house) I use these to hold lots of things from dock lines to trash. they fit nicely over the rail on a montauk,and have a velcro(s/p)on each side also. I have seen them in gray/blue/red/blk. they also have other bags that velcro to walkers. hope this helps. Guts |
andygere |
posted 03-07-2002 03:32 PM ET (US)
I swear by dry bags for carry-on stuff like jackets, hats etc. They are inexpensive at places like REI, and most importantly, they keep your stuff dry. I use the console to store binocs, charts, flares, a small set of tools, and other small items. I do have a teak casting deck across half the bow area, and a few drybags and PFDs easily slide underneath. In the port side stern corner, I have a white 5-gallon pail with a screw on gasketed lid. Inside is a sponge, gong brush, flushing muffs, and other misc. wet gear. I use the bow locker for the anchor and rode, dock lines and bumpers. |
bdb |
posted 03-08-2002 07:54 AM ET (US)
Hey Kid! Those are 54 qt. coolers. They protect that little stuff (battery & oil tank) from being everybody's favorite step. They pretty much span the beam and thus offer not only seating but reclining space too. I mounted rubber feet to their bottoms,so they don't slide around, and shock-cord mount them to the deck like the one in front of the RPS. Starboard cooler houses the equipment; port is used for cold storage. Hint: I cut a hole in the lowest corner of the cold storage unit, sealed the foam, and keep a rubber sink stopper in it. This allows complete draining of melting ice, cleaners etc. And it so happens that the hole is just adjacent to the tunnel, so it's a quick run to the sump. Unfortunately they are currently storing a foot of snow. Harpoon Harry, hibernatin' |
where2 |
posted 03-08-2002 12:51 PM ET (US)
54qt coolers? In my 15' Sport, I've got the 100qt as a dry storage locker. No center console to stuff things in, just the big white cooler. Swallows 4 PFD's, fire ext. flares, horn, towels, jackets, hats, spare prop, HH-VHF, etc. If it were much bigger, I could get a cushion and call it a "Sun-Deck". |
Denny |
posted 03-08-2002 06:39 PM ET (US)
Thanks for the cooler idea. I've got a 72qt up front and those bags in the back but the twin coolers seem like a good idea. Sorry about the snow I recall the term "lake effect" from my Chicago days I didn't care for snow that much. Here in Vancouver WA we are looking at about 7 days of rain. Not the kind of weather you want to be zipping around on the Columbia River in 40-degree temp. Denny |
bdb |
posted 03-09-2002 07:06 AM ET (US)
Hey Denny, Vancouver, WA is where my son Outrageman lives. Call him up and bother him! See, he doesn't have a Whaler, but he likes to look at them and talk about them! Harpoon Harry, in the middle on an ice storm. |
posted 03-09-2002 07:37 AM ET (US)
[Fixed some broken URIs] |
Denny |
posted 03-10-2002 01:38 AM ET (US)
Spoken like a true Father. I like to let my son know when I'm going out in the boat. His reaction almost pays me back for the College tuition. he he! Denny |
DaveIsaacs |
posted 06-24-2002 02:52 PM ET (US)
Harpoon Harry, Did you use the Igloo mounting kit (the "4 corners" with tie downs) for those 54 qt coolers? I'm assuming you didn't use the system that raises the coolers up because of the weight of the batteries. I am curious because it looks like I would have trouble mounting the four corner kit (because the length of the cooler would put the mount off the raised, flat portion of the deck). Did you use something else or is the bottom of the cooler significantly narrower than the overall dimension listed at 25-1/2"? -Dave- |
bdb |
posted 06-25-2002 09:43 AM ET (US)
Dave, I didn't use the Igloo mounts. I wanted to be able to remove these coolers if necessary, and still have an unobstructed deck. So, I mounted rubber "furniture feet" under the coolers, and to the deck I mounted 4 (2 on each side) little stainless "U" hooks, similar to those used for securing canvas webbing to the hull. The rubber feet elevate the coolers so water has a clear drain path, and keep them in placve. Rubber shock cords are run from one "U", up through a hole in the cooler's handle frame, and back to the other "U". The "Us" are mounted just shy of the cooler's corners, and as close to the cooler (almost underneath) as possible. This avoids deck clutter and toe-stubbers. The system works great. Lot's of storage, no clutter, no damage to battery or oil resevoir, cables neatly bound etc. Wonderful for reclining in the sun etc. I wish I could post some photos, but I can't. Perhaps I can get OutrageMan to perform that magic. Harpoon Harry |
T Party |
posted 06-25-2002 11:14 PM ET (US)
I raised my console on 4" mahogany blocks (in my 1978 Montauk). It was a big improvement for me. Also, the owner before me made and mounted a beautiful mahogany box on top of the console that i'm not sure i could live without. I keep meaning to take some pictures ans send them in, but I'm too busy enjoying the summer and the boat to clean her up enough to show off. I'll try to take some pictures soon. |
DaveIsaacs |
posted 06-26-2002 04:59 PM ET (US)
Harpoon Harry, Thanks very much. I picked up two 50-qt "UltraCool" coolers half-off at West Marine right now! |
bdb |
posted 06-27-2002 07:14 AM ET (US)
Yes Dave, I guess I didn't mention that I did cross-vent the battery cooler in case the battery gases. Four 1" vents, 2 fore and 2 aft. And yup, 5200. By the way both battery and oil tank are properly mounted within the cooler (screwed down mounts.) |
DaveIsaacs |
posted 06-30-2002 11:15 PM ET (US)
Harry, Do you remember where you found the 1" vents? Sounds like something simple but I couldn't find any - might have to go with a larger vent but the smaller the better with the way the cooler is contoured. -Dave- |
bdb |
posted 07-01-2002 07:06 AM ET (US)
Dave, I don't remember. They're round plastic, and are peppered with small holes. I looked for a long time, but am reasonably sure I found them in a marine store/cataloge. There were 4 or 6 mounted in a card. Holes covered by clamshell vents would work too. |
DaveIsaacs |
posted 07-02-2002 03:04 PM ET (US)
Thanks. I found them. Right in front of my face, by the clam shell vents at the West Marine. -Dave- |
Chap |
posted 07-02-2002 03:27 PM ET (US)
Hello, I was looking at the latest version of Outrageman's father's solution by Rabud. www.diy-boat.com/Pages/issues/magpages/projects/projects.html Mighty big hole though. Thanks |
WhalinWilly |
posted 07-03-2002 01:20 AM ET (US)
Hi Denny, Looks Like everone likes there front mounted cooler, but not as a cooler!!! My montauk has a mahogany cabinet in front of console. It has 8 drawers and measures 24" high 28 "wide and 10"at the bottom depth to 14" at the top. The unit is made to conform to the front of the console. It has a shelf on top to make sandwiches or for bait etc. The top shelf measures 13" deep X 27" wide. I love this cabinet, I use it for tackle, tools, first aid, parts, gloves, flashlight, etc. It's never in the way and it not as wide and bulky as the cooler. I have a 54 qt cooler that I put in the starboard side and in the stern. My battery is in the stern on the port side. My bulkier items I throw in the console or the front livewell if I'm not using it for fish. If you want pictures let me know as I will take some and send Email. Why all these smart chumps on here haven't figured this out is beyond me !!!! Good Luck |
bdb |
posted 07-03-2002 09:36 AM ET (US)
Liked the link to the Rabud thing. And yup, that's exactly the idea. The Rabud container may be a bit deep for the top of the console however. The container I used does not extend into the path of the side door when opened. And yup it's a big hole. Didn't have much choice as the previous owner had mounted some electronics in that area which left the console top looking like swiss cheese. Necessity is the mother, you know. Harpoon Harry |
Denny |
posted 07-03-2002 09:55 AM ET (US)
That cabinet sounds like a good idea how did you attach it to the boat? Denny |
WhalinWilly |
posted 07-03-2002 11:11 AM ET (US)
Denny, 4 Quater inch nuts , bolts and washers through the front of the console... 2 top, 2 bottom. It seems to be very secure with no movement at all. Bill |
Taylor |
posted 07-09-2002 09:15 PM ET (US)
To keep the things organized in my console, I got some nylon cable clamps and attached them to the mounting bolts for the rod holders that stick through inside the console. Then I threaded a little shock cord around, and used some inexpensve aluminum caribiners to hang things up. Lines and ditty bags hang pretty well. |
captndon |
posted 07-10-2002 04:26 PM ET (US)
Seems every posting here has the montauk battery in the stern, mine came mounted in the console and I have no oil res. Is there any advantage to moving it to the Capd |
Taylor |
posted 07-10-2002 07:38 PM ET (US)
I've been told that earlier whalers, like a Nauset came with the battery in the console. Montauks came with the battery in a tan battery box aft. The advantage of the console location is the weight is forward. This is supposed to be better, but I don't know why. It also looks neater, and keeps the aft cockpit clear. Disadvantages include the long run of the cables to the engine, and the loss of storage in the console. And if its in the stern to starboard, the weight help offsets torque lean. People on this forum who have moved the Montauk battery forward feel that its an upgrade. I suppose they would not do it otherwise. If its in your console and its working, I think you probably want to leave it there, but make sure that its not sitting on the plywood bottom of the console, which is not strong enough to take the load. It needs to be sitting in a hole cut through the bottom so it sits on the deck of the boat. |
sklein |
posted 07-10-2002 07:51 PM ET (US)
Regarding the Rabud thing, I made similar ones myself for my center console. The hatches are readily available. I used 4 inch thinwall PVC. Using a heatgun, the PVC can be stretched and flared out on the end to go over the bottom of the hatch flange and glued on. Use the glue that is good for PVC and ABS plastics. A standard end cap on the bottom, and you have a custom watertight compartment to your own length requirements. I built one about 6-7 inches deep and installed it on the port side forward corner of my console (above side door) for watch, wallet, glasses, keys, etc. I built another one about 24 inches deep and installed it on the starboard side forward corner for rolled charts. They work great - I highly recommend it. Steve |
Tom W Clark |
posted 07-10-2002 08:13 PM ET (US)
Actually, all the old Whalers had the battery in the back of the boat where it belongs, I mean where I prefer it. It was not until Whaler ownership slipped into the hands of Reebock that the battery found it's way to the console. Looks seemed to override practicality after CML lost control. The early Nausets, Sakonnets, ect had the fuel tanks in the console but the battery was always in the stern. In truth there are advantages and disadvantages to both placements. I strongly favor having the battery in the stern for the following reasons: 1) The battery will be accessible. Getting down on hands and knees to access either the side or rear door on the console is a real pain. If the battery is in the stern you can get to it as fast as unstrapping the lid of the battery box. 2) There will simply be more room in the console which is a very valuable commodity on a Montauk. On my two Montauks the console was the primary dry storage. 3) The battery cables will have a much shorter run. There will be less resistance in the run and the cost of replacing the cables will be much less. It will also be a far less likely to have a short or leak by nicking the cables if they are short and direct without going under water down the tunnel. 4) The battery will be better protected from pounding if it is in the stern. Choppy water will pound the Hell out of a Montauk and there is a huge difference between the ride in the stern and the ride at the console. Many people overlook this fact. If the battery is in the console it must be sitting on the floor or it will tear out the interior bottom of the console. 5) There will be less of spark hazard as well as no corrosive battery fumes if the battery is in the stern. Now the flip side: 1) If the battery is in the console the boat will be somewhat neater in appearance. But the appearance of all that wiring in the console will not be so neat. I am a guy who looks under hatches and behind doors. That’s my nature. I really like to see things clean and neat. Open up the console door on a Dauntless and see what you see. 2) The battery will be less vulnerable to “drowning” in the event the boat is swamped. Well, actually battery box lids will form a pocket of air over the battery terminals for a while and prevent a short from occurring. Furthermore, a battery immersed in sea water will, in fact, continue to function for a short period of time, enough to get the motor going and the water sloshing over the transom. 3) The weight will be forward. Well a group 24 battery weights about 45 pounds. There's usually lots a things in a Montauk that can be shifted to alter the weight distribution as much as a battery relocation to the console. Actually, on a Montauk, moving weight forward is not necessarily desirable. Being stern heavy is more of a problem on a Currituck or Sport model. My advice is to leave the battery in the stern, or if it’s in the console, move it to the stern and free up some dry storage space. |
TRIDENT |
posted 07-16-2002 12:04 PM ET (US)
I really like having the battery in the console. It is in a battery box sitting on the deck through a cut-out. It takes up little space because most of the battery box is below the level of the console bottom deck. The wiring is more protected from salt spray. The weight of the group 27 battery (I know-overkill) is moved forward, which helps the ride and balance of the boat. Too much weight aft is a bad thing on a Montauk, IMO. Especially if you anchor up where there are conditions in which you take waves from aft (like near a ship channel or jetty). I would recommend putting the battery in a battery box in the console. Happy Whalin' |
DaveIsaacs |
posted 07-29-2002 01:11 PM ET (US)
FYI, as promised here is a photo of the two coolers I mounted in the rear, following Harpoon Harry's idea: [url]http://www.villagephotos.com/viewpubimage.asp?id_=483619&uid=28330[/url> -Dave- |
bdb |
posted 07-30-2002 09:41 AM ET (US)
Dave, That's the idea! You'll really like the seating/storage option the installation gives you. Harpoon Harry, loungin' in the stern |
detra |
posted 08-07-2002 11:07 PM ET (US)
I really like your cooler seat system! I have a 73 nauset and am thinking of using this system. My only question is the accessibility of the bilge. Can you easily access the drain plug? detra |
scarlson |
posted 08-11-2002 12:15 PM ET (US)
Bought my 85 Montauk in 1985 and added the stern dec/live well with the casting chair and ski pylon also put on the front casting chair. Underneath there is a lot of room for batteries, tackle boxes, tool box, boat hook, paddle etc. The casking seats are the best seats in the house because they are made to sit in while the boat is underway. I usually use the live well as storage unless I'm perching and need it for minnows. If you look in the old brochures they usually show the seats and decks on Stripers, but the 17'Striper hulls were Montauk hulls without leaning post seat and standup console all other deminsions were identical. The reason I mention this is alot of Stripers had the rear deck anyone interested might want to scrounge around looking under 17' striper parts. I have the distinction of being the first Montauk owner that ever put in are rear casting deck. The first winter after I purchased the boat I ordered the deck which they shipped direct from Rockport. Got together with 4 buddies (all whaler owners) to put it in. Sent several hours trying to figure out how to get in between the rear rails but curved in just enough it would not slip down, could not take rear rail as deck blocks access to screws to remount. Called Rockport and talked to the shop that fabricated the rear deck. That's when I found out that while deck had been listed as an accessory for the montauk, I was the first to actually try and put one in after a motor had already installed! The ones in the pictures were installed before the motor was hung on. You guessed it they reccomended pulling the motor. We finally cut two pieces of wood just a 1/2 inch wider than the clearance needed to set the deck straight down between the rails. We gently spread the rails apart and wedged them apart and installed. The other option was to pull the leaning seat and unbolt the console and move it forward. On the Striper the seat was just a cooler and the short sit down helm sat further forward. By removing the cooler you could slid the deck in below the rails. Without the seat/pylon in you have space above and below. You might even want to check if Whaler still has the molds.The last options price listing I show it in is 1986. It isn't shown as an option in the 1997 list. In 1986 it cost me over $1,500 for everything. All still in excellant condition and never regreted spending the money. |
scarlson |
posted 08-11-2002 12:18 PM ET (US)
andiamo |
posted 09-08-2002 04:23 PM ET (US)
As many of you know I took delivery of a 1987 Montauk back in July. Prior to taking delivery I asked the dealer if he could instal some kind of rear bench/locker. His solution is amazing. He ordered a standard fiberglass bench for a Carolina Skiff and mounted it against the transom. The bench now stores the battery, 6 PFD's the fenders and a paddle with room to spare. It is a slightly less eligant way of adding the rear storage that has been shown on here before with the custom made Montauk rear bench. Some purists might argue I have added too much weight to the rear but the static trim seems fine (the water line on the engine when raised seems to be on the old marks). And more importantly for me the boat is now more functional and less cluttered than before. (Now all I need to do is replace my old Evinrude 90 with something lighter and I will have off set this) Anyway for those of you who are looking for an easy way to increase both the storage and seating capacity of your Montauk I would recommend looking at this. |
