  Sparky Plugs :)
Author Topic:   Sparky Plugs :)
Magnum posted 04-11-2002 06:51 PM ET (US)   Profile for Magnum   Send Email to Magnum
I currently have an '84 Johnson 140 2-stroke "Looper" engine on my boat and the plugs have lasted about 13 years. I know that's probably crazy, but the aged gentleman that I bought the boat from said that all he did was brush the ends when it needed. The plugs are Autolite (#2892) and I would like to replace them or have a back-up set handy. I wanted to go with NGK (#BUHXW-1), but I have been told that they fowl quite often in 2-stroke engines. My other choice is a Champion (#UL77V), or I could just go back with an Autolite :) Basically, I'm open to suggestions!
David Ratusnik posted 04-11-2002 07:51 PM ET (US)     Profile for David Ratusnik  Send Email to David Ratusnik
OMC='s Champions. Buy on sale. David
whalernut posted 04-11-2002 08:27 PM ET (US)     Profile for whalernut  Send Email to whalernut
I have found at top end it doesn`t really matter, but I have tried them all litterally and I know my 1975 Johnson 85h.p. V4 likes the Denso brand the best in all ranges, especially shines in the Trolling Slow mode, they don`t foul easily or stall out easily, hands down the best plug for the money. Now on a 9.9h.p. outboard, it seams those things will run great on anything at any speeds!! Jack.
Dick posted 04-11-2002 08:29 PM ET (US)     Profile for Dick  Send Email to Dick
In all of the shops I have worked at we have used NGK in everything with no performance complaints from any customers.
The only engine I have ever encountered that liked Champions better were the early Force 85s. Wouldn't think that old Chrysler ignition system would be that pickey.
gunnelgrabber posted 04-11-2002 09:26 PM ET (US)     Profile for gunnelgrabber  Send Email to gunnelgrabber
in a past life i learned it doesn't take much to strip the threads in alloy heads with a sparkplug...as in bringing the threads out with it? i'd remove them periodically even if they did last 13 years...lm
Wille posted 04-11-2002 10:54 PM ET (US)     Profile for Wille  Send Email to Wille
"If it ain't broke, don't fix it." Go with the replacement plug that is working well for you now.
Or run your own test with various plugs and post it here!
Magnum posted 04-12-2002 08:18 AM ET (US)     Profile for Magnum  Send Email to Magnum
Thanks yall! I believe I'm going to try the Champions, but before I stick with them, I will run that test per Wille...
