  68' bow lights
Author Topic:   68' bow lights
Troys toys posted 04-28-2002 06:31 PM ET (US)   Profile for Troys toys   Send Email to Troys toys
I am starting a slow rebuild on a Nauset I just got and I have no info on wiring . Does the wiring run in the hull or under the rub rall on a 68' 16' Nauset.Any info on this project will be welcomed. Thanks Troy
whalernut posted 04-28-2002 08:03 PM ET (US)     Profile for whalernut  Send Email to whalernut
I believe the wireing is in the foam in the hull. If you are replacing the rubrail, you can re-run it under there. Are you useing the older white rubrail or the newer Black ir the Classic Whalers or the ones that the New Whealers use?? Jack.
rwest posted 04-29-2002 01:17 PM ET (US)     Profile for rwest  Send Email to rwest
I redid my 35 y.o. Nauset last winter and ran the wiring thru the two piece black rubrail down the port side and drilled thru the gunwale. I sealed around teh opening I drilled both at the bow and at the stern. I tied it into the existing terminal block at the port transom where the stern light was located,and then ran wires from it to the center console. The older wires in the foamed hull did not hold up on either of my two early whalers
Troys toys posted 04-30-2002 10:14 PM ET (US)     Profile for Troys toys  Send Email to Troys toys
Thanks guys for a quick reply,Ihave not yet made up my mind which way to do the rewire,but wil probablyrun it under the old white rubrall first. If this does not look good I will ask for more help. Thanks again
Troy
Troys toys posted 04-30-2002 10:29 PM ET (US)     Profile for Troys toys  Send Email to Troys toys
More questions on the 68' rebuild. Does any one have a diagram of the orginal wood console. Good pictures will help,you know the old saying,"If I see it I can build it".
Thanks Troy
DanT posted 05-01-2002 07:48 AM ET (US)     Profile for DanT  Send Email to DanT
TT, I sent a copy of the original console plans to you. Good luck with your project.
Whaler Proud posted 05-01-2002 09:50 AM ET (US)     Profile for Whaler Proud  Send Email to Whaler Proud
Dr T.: Any way I can get a set of those plans? I have a '68 also and would like to build an original console for it.
Thanks
WP
DanT posted 05-01-2002 11:39 AM ET (US)     Profile for DanT  Send Email to DanT
WP, They are on their way.
Whaler Proud posted 05-01-2002 11:58 AM ET (US)     Profile for Whaler Proud  Send Email to Whaler Proud
Thanks Dan
EddieS posted 05-01-2002 12:31 PM ET (US)     Profile for EddieS  Send Email to EddieS
Troys Toys,
I am just finishing a restoration of my 66 Nauset. I would definetly replace your rubrail with the new 3 piece style. You can get it from Twin Cities for about 85.00 plus shipping. You are going to have a very hard time getting 16/2 marine grade wire under your old rub rail. The newer style has a channel inside the black rubber piece that hides the wires perfectly.
The newer style rub rail offers much better protection and really makes the boat look nice. With all of the time and money that I have spent on my restoration project, this is one of the last things that I would skimp on!
My opinion, good luck however you decide to go.
Ed
whalernut posted 05-01-2002 02:20 PM ET (US)     Profile for whalernut  Send Email to whalernut
Dan, would you please send me a copy of the plans too??? Thank you-Jack.
DanT posted 05-01-2002 04:34 PM ET (US)     Profile for DanT  Send Email to DanT
Jack, I just sent them out.
Whaler Proud posted 05-01-2002 04:39 PM ET (US)     Profile for Whaler Proud  Send Email to Whaler Proud
Dan T: Many thanks for the plans. They printed out great and I'll make this a project for the woodshop this winter.
WP
whalernut posted 05-01-2002 05:44 PM ET (US)     Profile for whalernut  Send Email to whalernut
Thanks Dan!!!! Jack.
Taylor posted 05-01-2002 06:09 PM ET (US)     Profile for Taylor  Send Email to Taylor
Those plans ought to be posted on the website. Seems like a popular request.
