  hatch cover repair
Author Topic:   hatch cover repair
Smallfrye posted 06-03-2002 03:10 PM ET (US)   Profile for Smallfrye   Send Email to Smallfrye
The front hatch covers of a 22OR are separating along the bottom side seam. This exposes the interior material , which in some cases is rotten or missing totaly. I believe this was a Mfg problem but the boat is now out of warranty. In cases of small voids, I have filled with epoxy augmented with filler. The two on this boat have large voids, maybe one foot square. What would you all suggest to repair this ?
John O posted 06-03-2002 08:48 PM ET (US)     Profile for John O
Have re-glassed ,cost about 100.00. My is doing the same thing. I will wait till the winter when the repair guys have less work.
JBCornwell posted 06-03-2002 09:02 PM ET (US)     Profile for JBCornwell  Send Email to JBCornwell
Hi, Jim.
EBWC made me a OR-18 teak locker cover for under $200. It is exquisite!
If you'd like a pic. E me.
Red sky at night. . .
JB :)
outrage22 posted 06-04-2002 12:33 AM ET (US)     Profile for outrage22  Send Email to outrage22
If you dont mind some work it is easy to fix. i had to fix mine. they are actually foam filled just like the boat. you have to "disect" them by cutting the underside skin off with a dremel, grind out all the foam, cut a piece of 1" plywood to replace the foam, use epoxy resin to bond in, clamp together (i parked my car on top of it) then you can either bond the underskin back on or lay a sheet of fiberglass mat and gelcoat. email for more detailed info.
Eric
