Topic: Improved anchor light reliability.
triblet |
posted 06-04-2002 08:01 PM ET (US)
The anchor light on my Montauk has always been somewhat unreliable. I THINK I've finally got it licked. I found three sources of unreliability: 1. The bulb in the socket. Replacing the socket with a new one (it's a standard Perko part, West stocks them) and coating things with Dow-Corning 111 Silicone grease fixed this one. 2. The flat quick disconnnects to the switch kept quickly disconnecting. The biggest problem was the multiple layers of piggy backed connectors. I rewired things so that there's pretty much just one connector on each (I didn't bother with one). This is done by using connectors for large guage wire (say 10-12 ga) and putting multiple smaller (say 14-16 ga) wires into it before crimping. I also changed the circuit a little so the net effect is the same, but there are fewer wires. 3. The round plug at the base of the mast. I ran new 18 ga. Ancor boat cable all the way from the socket to the switch. It's permanently threaded through the mast holder. No more plug. Chuck
Boston Marine
posted 06-04-2002 10:56 PM ET (US)
On [my] Outrage [I] just installed a complete set of new gauges. Instead of just crimping, [I] soldered all the grounds as one continious wire from gauge to gauge. The same was followed for lighting. The fuse pack is packed with silicone paste. As far as senders, [I] re-terminated all wires with copper eyes crimped and then soldered. New ignition switch (The potted model with pigtails) was installed. The wires were connected by soldering. [I] don't believe crimping alone is enough. Soldered connections are absolutley foolproof. Chuck, you are correct to use silicone paste and that is what [I] do also. Keeps air and moisture out of slip connections. Just my .02 Greg |
posted 06-04-2002 11:20 PM ET (US)
[Edited post to change grammar from first-person, plural, to first-person, singular. Generally the first-person plural is used by a royal head of state, like a King, when referring to himself.--jimh] |
andygere
posted 06-05-2002 04:12 PM ET (US)
Chuck, with your anchor light now hardwired, do you leave the mast up all the time, or did you just leave enough wire to stow it nearby? |
lhg
posted 06-05-2002 07:22 PM ET (US)
I solved the stern pole "plug" problem by switching to the molded rubber flat 2 pole connectors. These are a twin to the standard 4 pole trailer light connector. Available at Pep Boys & most good boat stores, where they cost more! |
triblet
posted 06-06-2002 12:40 AM ET (US)
I left enough slack to stow the mast in the factory rubber clips.I considered using the two pole bullet connectors (like a four wire trailer connector, but only two wires), but I couldn't find any that were truly marine grade. I found some wannabes (Perko?) but the wire wasn't tinned. The problem wasn't the crimp to wire joint, but rather the flat QD connections to the switch, which used (in one case) piggyback connections three deep. The three were running light, instrument lights, and binnacle light. I moved the binnacle light to the end of the instrument light daisy chain (crimped on eye), and put the other two into a single crimp QD. So now the QDs is only one deep. I think that a properly done crimp is just fine. Proper means using the Ancor crimps with glue lined heat shrink for strain relief and sealing. And a GOOD crimp tool ($50, not one of the $3 ones from the hardware store). I've had zero problems with crimp connections, and this is on a salt water boat (sorry, WhalerGuy, you don't want it ;-) that gets used for diving almost every weekend day (I think I've launched 35 times this year). For what it's worth, NASA uses crimps. And so do lots of airplanes. Soldering has to be done right. If you flow too much solder in, and it goes up the wire past the strain relief, the wire can break at the stress riser where the wire ends. Chuck
andygere
posted 06-06-2002 02:21 AM ET (US)
Chuck, Where on your boat are the rubber clips located? |
triblet
posted 06-07-2002 01:15 AM ET (US)
Dunno the proper nautical term, but the inside of the starboard gunwale. West Marine carries a similar clip.Chuck |
andygere
posted 06-07-2002 11:43 AM ET (US)
Thanks Chuck. I picked up a pair of the clips at the Outboard Motor shop a while back, and have been trying to figure out where to mount them. I like the idea of hard wiring the mast. I am getting tired of having to clean the oxidation off my connector plugs every time I use the anchor light. |
Salmon Tub
posted 06-07-2002 06:31 PM ET (US)
Andy, I have those same clips in the factory spot and don't like them there. It tend to get in the way of passengers and they end up kicking the pole and or stepping on the plug. You may want to consider mounting them vertically between the rod holders next to the shepard's hook rail. As for keeping the connectors clean, you can buy an extra set (male and female) and use them as covers to protect the existing ones. Just a thought. |
triblet
posted 06-07-2002 08:27 PM ET (US)
I don't have any problems with passengers and the pole mounted in the factory location. Chuck
Ed Z
posted 06-07-2002 11:09 PM ET (US)
I too use crimped connections all through the boat... The only difference in my method is that I stick the stripped part of the wire into some vasoline and then into the connector... I then use the glue lined heat shrink to seal the joint and privide the strain relief... During a rewiring job (changed out a bunch of the electronics) I cut open a few of the crimp connections I had made many many years ago and found them to look as good as the day I had done them... |
Boston Marine
posted 06-08-2002 07:31 AM ET (US)
Chuck, I do solder "right" |
andygere
posted 06-08-2002 03:14 PM ET (US)
ST, I like your storage idea on the front of the console. I use the dummy connecter trick to keep my trailer wires from oxidizing, and I don't know why I didn't think of it for the anchor light. I think I even have a spare set lying around.... |
