  colllasped squeeze bulb
Author Topic:   colllasped squeeze bulb
scottfarm posted 06-06-2002 05:04 PM ET (US)   Profile for scottfarm   Send Email to scottfarm
Was having trouble with 1995 merc 75hp cutting off while idling. Could pump bulb and would run fine. Replaced all fuel line and squeeze bulb and now it collaspes the bulb while running. The air vent tube is unobstructed. I even opened the gas cap while running and the bulb stills stays collasped. What could the problem be.
ratherwhalering posted 06-06-2002 05:08 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
Could be a clogged pick up tube in the tank. depending on the tank, they usually have a screen at the bottom of the tube, at the bottom of the tank.
ratherwhalering posted 06-06-2002 05:10 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
does the arrow on the bulb follow the fuel flow?
scottfarm posted 06-06-2002 05:25 PM ET (US)     Profile for scottfarm  Send Email to scottfarm
Yes I have the arrow right. I have a 31 gallon aluminum fuel tank. I will check the fuel pickup tube. thanks
Steve Leone posted 06-07-2002 12:14 AM ET (US)     Profile for Steve Leone  Send Email to Steve Leone
bad bulb. steve out
scottfarm posted 06-09-2002 05:04 PM ET (US)     Profile for scottfarm  Send Email to scottfarm
Steve, you were right bad bulb.I had replaced all fuel line with new bulb. The new bulb was bad. You de man
