  Filling Drilled Holes in 11' Tender
Author Topic:   Filling Drilled Holes in 11' Tender
John Wilke posted 06-13-2002 10:25 PM ET (US)   Profile for John Wilke   Send Email to John Wilke
I just purchased an 11' Tender which was used for snorkeling. The hull has several 1/8 inch holes which were used for an anchor setup. What material should I use to repair or fill these holes?
lucky 13 posted 06-14-2002 10:32 AM ET (US)     Profile for lucky 13  Send Email to lucky 13
I just had to do this as well. What I did was (and it worked out pretty well) was to lightly dress each hole with a dremel tool and than I mixed some fiberglass resin with some light blue gelcoat coloring. Then I took some chapped strand (fiberglass matt) and snipped some small fibers with scissors ( finely chopped up) and mixed them into the resin to form a light paste like consistancy. I put some masking tape around the holes to keep it clean and then smeared the paste into each hole. When the resin dried, I removed the tape and redressed the holes with the dremel tool to match the non-skid texture. My color match was pretty good and the holes are no more.
John Wilke posted 06-14-2002 06:41 PM ET (US)     Profile for John Wilke  Send Email to John Wilke
Thank you, I will give this a try!
