DrAlan |
posted 06-25-2002 09:46 AM ET (US)
Purchased a used Whaler 27 (26'7") V birth, and can't find much info on design, specs, retrofits, etc., even from Whaler themselves. For instance, between the inner wall and outer hull, 6", has no foam or frame work but for a 1"x2" at the base, which has come loose. Thus the inner wall has separated from the floor (repair options?). And I would like to mount scuba tank racks, but to what? Also, a source for replacement/repair parts, like I can't find the little reverse "scoop" (for creating a water flow under way to pull the water out of the bilge areas..) Whaler mounted in front of the drain holes (3) on the bottom of the boat? Any suggestions?
