  drain tube in anchor locker on 13' SS
Author Topic:   drain tube in anchor locker on 13' SS
T_Bro posted 07-09-2002 01:26 PM ET (US)   Profile for T_Bro   Send Email to T_Bro
Finally got back to Martha's Vineyard over the 4th and got to play with my 1986 13' SuperSport and found a couple of trouble spots. The boat was full of leaves and when I cleaned it out, I found the drain plug on the anchor locker was plugged. I rooted around with a plastic stick and unclogged the blockage. However, it seems that the passage is not sealed and that the water leaks into the foam? Is there supposed to be a brass drain tube in there, or was it formed into the gelcoat? Although it seems to drain propoerly now, what can I do to prevent further damage to the foam?
Thanks,
Todd
Bigshot posted 07-09-2002 02:17 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
No tube there. Just gel coat or whatever. Fill with some epoxy and the drill out if you think water is getting in there.
dburton posted 07-10-2002 04:36 PM ET (US)     Profile for dburton  Send Email to dburton
I assume you are talking about the bow locker, if not this maybe a solution for your situation. Get a flexible tube (vinyl or other material) of the correct outside diameter from the hardware store. Thread it through the opening and cut flush while bedding with 3m 4200.
I covered the exposed part on my 13 sport with a small clam shell vent.
