  Gelcoat over Alwgrip?
Author Topic:   Gelcoat over Alwgrip?
Gep posted 07-13-2002 01:00 AM ET (US)   Profile for Gep   Send Email to Gep
Can you use Gelcoat to touch up over Awlgrip?
Or is this not a good idea?
Mike
OutrageMan posted 07-13-2002 07:07 AM ET (US)     Profile for OutrageMan  Send Email to OutrageMan
My gut tells me that is not a good idea.
Brian
Gep posted 07-13-2002 10:02 AM ET (US)     Profile for Gep  Send Email to Gep
Where would I pick up some Awlgrip?
dfmcintyre posted 07-15-2002 08:32 AM ET (US)     Profile for dfmcintyre  Send Email to dfmcintyre
check your local automotive paint supplier store. It will be the one that supplies paint and body repair products to the car dealerships and independant body shops in your area.
Best bet for paint match, is to tow your boat right to the shop and have then analyze the color with a portable device which then downloads the info into their computerized mixing system.
Don
Chesapeake posted 07-15-2002 02:45 PM ET (US)     Profile for Chesapeake  Send Email to Chesapeake
Surprisingly, I believe you can order from West Marine all three parts. It is not cheap.
world2xplor posted 07-17-2002 11:31 PM ET (US)     Profile for world2xplor  Send Email to world2xplor
Please doublecheck this with any of the companies that sell marine paints/gelcoats, but I believe that there is a problem with using gelcoat over Awlgrip, being that Awlgrip is an epoxy based product and gelcoat is a polyester based product. I just recently ran into the same problem after having done a lot of fiberglass repairs/renovations with West System Epoxy and wanting to finish the job with gelcoat. The guy who will be painting the boat informed me that I couldn't use gelcoat (polyester) over epoxy resin, because the chemicals won't tolerate one another. I wouldn't settle for that being the end of my months of hard work, so I investigated via the net and ended up contacting several different manufacturers of various gelcoats/paints/etc. Before long I was informed that the job could indeed be done if I would simply use a tie-coat, several manufacturers (s.a. Ferro) or by using a vinylester primer as an intermediary between the epoxy and the gelcoat. I believe that this is probably what you will have to do as well in order to get the gelcoat to adhere to the Awlgrip. Good Luck. Jed
