  Evinrude Misfires
Author Topic:   Evinrude Misfires
Ian posted 09-01-2002 06:24 AM ET (US)   Profile for Ian   Send Email to Ian
My [1989 Evinrude 50-HP outboard] has a periodic misfire at any throtle position. I thought it was a spun hub but this was not so . One new prop later, replaced CDI unit but problem persists. Fuel tank is good, carbs are clean. Any suggestions? My mechanic has no idea.
JohnAz posted 09-01-2002 10:52 AM ET (US)     Profile for JohnAz  Send Email to JohnAz
Disconnect the ignition wire at motor end and see if runs smoothly. Ignition system runs on an open circuit. The problem might be in the harness between engine and key switch.
ratherwhalering posted 09-03-2002 01:23 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
This may sound silly, but I had the same kind of problem with a 90-HP Johnson. It just seemed to 'buck' at any speed, but only on occasion. Ended up that it wasn't the engine at all. The shifting cable was too loose. I tightened the cable (actually extended it to push it farther into forward gear). Problem solved, hasn't done it since.
Bigshot posted 09-03-2002 02:07 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
Bucking can be lower unit as stated above but usually will only do it on plane.
Ian posted 09-04-2002 07:29 PM ET (US)     Profile for Ian  Send Email to Ian
My mechanic checked the grounds in the wiring to the control box and found a bad ground. We fixed it but the problem persists. We are going to try a new wiring harness and see if that takes care of it. Thanks for your help.
Ian posted 09-07-2002 05:41 AM ET (US)     Profile for Ian  Send Email to Ian
Yesterday i replaced control box, wiring harness, control cables and CDI. The problem continues. Mechanic says"i don't know what it is"......help
DJS posted 09-07-2002 01:01 PM ET (US)     Profile for DJS  Send Email to DJS
Ian,
The website listed below is about repairing older outboard motors. Some of the people on it are professionals; they own their own shops.
http://pagebiz.com/bds/motor/motorboat.html
Hopefully someone there will be able to help you.
David
jimh posted 09-07-2002 04:43 PM ET (US)     Profile for jimh  Send Email to jimh
The hyperlink above leads only to a "Error-404--NOT FOUND" result.
jimh posted 09-07-2002 04:51 PM ET (US)     Profile for jimh  Send Email to jimh
[Corrected spelling of EVINRUDE, America's most famous outboard engine, throughout the postings--jimh.]
Dick posted 09-07-2002 05:16 PM ET (US)     Profile for Dick  Send Email to Dick
I sure can't go along with "Evinrude is America's most famous outboard engine". Where did this fact come from?
Ian posted 09-12-2002 10:58 AM ET (US)     Profile for Ian  Send Email to Ian
How about my engine problem???
shoctor posted 09-12-2002 01:22 PM ET (US)     Profile for shoctor  Send Email to shoctor
Have you looked into the coils at all I know you said you replaced the CDI bof but on your motor does that lead into the coils? Also is the engine losing a charge from a bad stator or charge wheel. When you replace all of those parts (not cheap as i have done the same) and mechanic says "I don't know" my next answer would be to look for a new mechanic. Is this guy a reputable mechanic did they fire the engine in test tank etc etc. Where are you located I am sure some forum member knows a good mechanic in your area
DJS posted 09-13-2002 05:57 PM ET (US)     Profile for DJS  Send Email to DJS
re: my reply of 09/07/02.
The correct url is:
http://pagebiz.com/bds/motor/motorboard.html
David
Ian posted 09-16-2002 03:49 PM ET (US)     Profile for Ian  Send Email to Ian
I am located on the south shore of NS. I will try another mechanic i think. Maybe someone knows a good evinrude mechanic in these parts.
