  Newport Bow Windshield Replacement Tips and Procedure
Author Topic:   Newport Bow Windshield Replacement Tips and Procedure
Harles posted 10-04-2002 11:02 AM ET (US)   Profile for Harles   Send Email to Harles
After some trial and error, I found out the easiest way to replace a Newport Bow Windshield.
First - You need the windshield - available through Sue Lodel at Twin Cities Marine in Two Rivers, WI 920.793.2715 or tcmarine@lakefield.net (Cost ~ $225). Be sure to order the windshield without the bolt holes drilled.
Second - You need the hardware available by Taylor Made Products 518.773.9449 or Special Order from West Marine:
Chrome Wing Brackets - Part #1607
Internal Angles w/ Gromets,bolts, etc... - Part #1601
White Twin Flap Vinyl Deck Channel part #826575
(Cost ~$45 not including shipping)
Third - Wait for your parts to come in. Windshield took 3 weeks, hardware took 2 weeks.
Fourth - Remove old winshield, if applicable.
Fifth - Install Wing Brackets (Trust me on this one) but do not tighten fully as you will remove them later.
Sixth - Place windshield onto wing brackets and mark the location of the bow bolt holes onto the windshield. I used a perm. marker.
Seventh - Drill bolt holes approx. 1-1/2" from bottom of windshield. Start with smaller bit and work your way up to a bit the size of the grommet that comes with the internal angles.
Eighth - Install internal angles onto windshield (not onto the bow of the boat). Do not tighten all the way.
Ninth - Install Vinyl Deck Channel on windshield. Leave some excess on the ends.
Tenth - Remove Wing Brackets
Eleventh - Now place the windshield assembly into the bolt holes on the bow. Install nuts under bow, but do no tighten fully.
Twelth - Install Wing Brackets Again. You may want to line up wing brackets first, cut the vinyl to fit into the wing bracket, locate bow hole on the vinyl, and make a bolt hole in vinyl. You may tighten the Wing Brackets for full installation.
Thirteenth - Tighten Internal Angles at Windshield.
Fourteenth - Tighten Internal Angles under Bow.
TA DA!!!!!!
The whole process took me about 2-1/2 hours with much trial and error. However, after figuring out the right way to do it. It only took me 1 hour.
PS - I had to go to the hardware store to get new bolts for the internal angles. Be sure that the bolts for the Bow side fit correctly. I also had to purchase a hand-driven socket set?? the one with a hollow interior that looks like a screw driver. This is so the bolt can slip through the center of the socket as deep as it needs in order to tighten the bolt (I forgot the formal name of it). You will need this under the bow as some of the bolts are difficult to reach with any other wrench.
Sorry so long, I hope this helps
Harles......
Harles posted 10-04-2002 11:11 AM ET (US)     Profile for Harles  Send Email to Harles
Another handy tool - Exacto Knife.
John O posted 10-04-2002 11:43 AM ET (US)     Profile for John O
GREAT POST !!! I plan on installing wind shield as well. Previous ower removed and filled holes on bow platform. I have a used one coming sometime. I think the shield looks great. Nice addition.
John O
Sam Collins posted 06-09-2003 03:23 PM ET (US)     Profile for Sam Collins  Send Email to Sam Collins
Bump
Bigshot posted 06-10-2003 11:02 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
For those interested....go to Home Depot or wherever and buy the smoked lexan and make your own windscreen for about $40. There are just 2 slight bends on it and a hair dryer will do the trick. you can also make your own console windshield for about $50-60.
When I make my new one I may make a few if people are interested.
small craft advisory posted 06-12-2003 03:12 PM ET (US)     Profile for small craft advisory  Send Email to small craft advisory
Bigshot, I would be interested in a windsheild or a pattern for one. Converted my 16'7 Katama to Montauk configuration. Bought the bare console and built it up from scratch. Waiting for the railing and just need a windshield to complete. Let me know! Thanks in advance, Lance.
Bigshot posted 06-12-2003 03:26 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
I am making the Newport bowshield, not the Montauk windshield.....sorry.
Would not be hard to do from scratch though. Just buy a sheet of tinted lexan with the length and height you need and then measure and bend then cut and grind smooth. Be careful drilling the mounting holes so it don't crack after all the hard work.
LuckyLady posted 06-16-2003 01:59 AM ET (US)     Profile for LuckyLady  Send Email to LuckyLady
BIGSHOT...
Are you able to bend the Lexan with a hair dryer 90 degrees?
Rene'
Bigshot posted 06-16-2003 11:13 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
Sure! I will know more when I start making a new sprayshield for my new newport. I have no template and will be winging it. If hairdryer won't work a heat gun is less than $20 and will melt the thing to goo if ya like.
Bigshot posted 07-30-2003 12:58 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
Few quick things:
Harles shows "Chrome wing brackets- part #1607" Taylor made's catalog shows part #1605. He also says "White twin flap vinyl deck channel part #826575" Catalog shows that as a 75' roll and the 110"(9+') is #826500. Can anyone verify his/their right numbers?
Also NO mention of part #1607 which is the hidden angle mounts(4per pk). Do we use these and are 4 enough?
Now does the internal angles w/grommets,etc part #1601 fit? Inside the Chrome wing brackets? If not what is their purpose or do we NOT need the #1607 and use the 1601 on the deck?
I have no hardware and sold the Newport before I could really get into it. I also did not want to mess with it being the winshield, channel, etc were in despair but functional. Please advise or if someone could send me a pic I would be VERY appreciative. Also Taylor is down the street from me so I can go there and get the parts, here is a list of offices:
Taylor Made Systems
Taylor Made Systems New York
93 South Boulevard
Gloversville, NY 12078
TEL: 518-773-0636
FAX: 518-773-2919
Regional Sales Offices
Florida
2750 Kansas Street
Oviedo, FL 32765
Tel: 407-366-5504
Fax: 407-366-6864
1900 47th Terrace East
Bradenton, FL 34203
Tel: 941-747-1900
Fax: 941-749-5000
Minnesota
19397 Vernon Street Northwest
Elk River, Minnesota 55330
Tel: 763-241-8100
Fax: 763-241-0036
New York
93 South Boulevard
Tel: 518-773-0636
Fax: 518-773-2919
Oklahoma
3209 S. 101 East Avenue
Tulsa, OK 74146
Tel: 918-628-1194
Fax: 918-663-9670
Tennessee
12185 Hatmaker Lane
Knoxville, TN 37932
Tel: 423-966-6295
Fax: 423-966-6296
Manufacturing Facilities
Florida
Taylor Made Systems Bradenton, Inc.
Bradenton, FL 34203
Tel: 941-747-1900
Fax: 941-749-5000
Taylor Made Systems Fabric Engineering Center
4854 Distribution Court, Suite 11
Orlando, FL. 32822
Tel: 407-737-3692
Fax: 407-737-1890
Georgia
Taylor Made Systems Georgia, Inc.
West Second and Victory Drive
Tifton, GA 31794
Tel: 912-387-0492
Fax: 912-387-6396
Indiana
Taylor Made Systems Indiana
1101 Stonebraker Drive
Kendallville, IN 46755
Tel: 260-347-1368
Fax: 260-347-4618
New York
93 South Boulevard, Gloversville
NY 12078
Tel: 518-773-0636
Fax: 518-773-2919
Ohio
Taylor Made Glass Ohio, Inc.
Curved & tempered glass
P.O. Box 77, 316 North Laura Street
Payne, OH 45880
Tel: 419-263-2313
Fax: 419-263-2661
Australia
Taylor Made Systems Pacific Partnership
Brisbane Plant
43 Randall Street, Slacks Creek
Brisbane, 4124, Queensland, Australia
Tel: 0061-7-3808-1513
Fax: 0061-7-3808-5025
Ireland
Taylor Made Glass & Systems, Ltd.
Templemore, County Tipperary, Ireland
Tel: 353-504-31411
Fax: 353-504-31986
New Zealand
Auckland Plant
35 Roscommon Road
Papatoetoe, Auckland, New Zealand
Tel: 0064-9-278-9816
Fax: 0064-9-277-6771
jstachowiak posted 07-30-2003 10:09 PM ET (US)     Profile for jstachowiak  Send Email to jstachowiak
Bigshot,
There are 6 angle brackets that hold the windshield to the deck. They are threaded and nuts and washer go on underneath deck. Attaches to windshield with rubber grommet and round head bolt and nut. The wing brackets hold the corners (two) of the windshield and have two phillips head countersunk screws. You might want to order a couple extra as I see mine are already pitted and only 9 months old. The rubber channel I ordered from Taylor by the foot. The guy I talked to was real nice and new what I wanted. I can send pictures if you still need.
Jeff
Bigshot posted 07-31-2003 10:39 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
Please do and how tall is the windshield?
jstachowiak posted 07-31-2003 02:07 PM ET (US)     Profile for jstachowiak  Send Email to jstachowiak
I'll get pics and measurement to you tonight.
Did you see this: "Since I didn't hear from anyone, I called Taylor Made. A previous posting in the Repair/Mod forum had suggested a part #826575 however this turns out to be a whole roll (?75ft) of it. The correct part number is 8265000 and they will sell it by the foot."
And this:
"Part: A-White Twin Flap Vinyl Deck Channel part #826575 B-Chrome Wing Brackets part #1605 C-Aluminum Internal Angles part #1601
Usage: Newport Front Windshield Hardware
Vendor: Taylor Made Products of New York
Phone: 518-773-9449
Contact: Cindy Pollard
The Windshield itself is still availible through Twin City Marine at tcmarine@lakefield.net"
Bigshot posted 07-31-2003 02:33 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
BW can KMA for $250 for a piece of plexiglass. I will make my own....maybe a few if easy enough. COlor will probably be darker but who cares, maybe a green one?
John O posted 09-04-2003 09:34 AM ET (US)     Profile for John O
Can Part # 1607 be used instead of the Alum Internal Brackets?
These are the Hidden Hold down fasteners with nuts and rubber grommets.
Gep posted 09-04-2003 12:39 PM ET (US)     Profile for Gep  Send Email to Gep
Bigshot,
Good luck bending that plex with a heat gun or a hair dryer.
The heat gun will get it hot enough to bend it but it will be hard to get the bend straight and true.
We use alot of plastic in my line of work and I actually got to see first hand how they bend plastic.
What they do is build a jig for the piece you want to bend. They cover this with some sort of cloth (velvet?), then they lay the piece of lexan (plex) on the jig and stick it in a regular oven. Bake it at 350 degrees until its soft.
Pull it out of the oven and let it cool.
I know it sounds like I'm baking cookies, but thats how they do it.
Mike
JeffA posted 09-04-2003 11:58 PM ET (US)     Profile for JeffA  Send Email to JeffA
Bigshot, When you get done making the front windshield for the Newport, would you be willing to share the template? I have a 1977 and I assume the dimensions are the same for all years ???
Jeff
John O posted 09-05-2003 01:03 AM ET (US)     Profile for John O
Bigs..I have a Newport bow windshield that is snapped in half. If it would help you I could ship it down to you.
It was given to me by another CW member but unfortunately snapped in half in transit. I have since purchased another used one and plan on installing this fall or next spring.
Let me know
John O
triblet posted 09-05-2003 02:21 PM ET (US)     Profile for triblet  Send Email to triblet
It's called a nut driver.
