posted 10-08-2002 05:46 PM ET (US)
Howdy, Spindlepoint.Sounds like a simple float/needle problem in the carb. Very easy to fix, and at the same time do some preventive maintenance.
A good factory Service Manual will cost you about $30. Carb, fuel pump and water pump overhaul parts maybe another $30-$40.
A basic tool kit is all you would need to do the work.
Then you will have a wrench you trust, who will deliver the engine promptly and not charge you $75 an hour to replace a lot of stuff that isn't broken.
www.iboats.com has manuals, and their Forum has some of the best OMC wrenches in the world to assist you with any problems. Ask for Joe Reeves.
Good luck.
Red sky at night. . .
JB
